Uwe's 88
Forum for discussion relating to the 88mm Flak36
Uwe Gerstenmayer
Been liked: 65 times
Re: Uwe's 88
Post by Uwe Gerstenmayer »
:roll: small progress on some parts,
made the bolt mods for the cruciform , sweating to get the 1,2mm treads in :shock: :lol:
and some more on the wheel section...
I've received today the hex bolts with more adequate head size and tried it on the housing, looks quite good for me now :)
cheers ,
Uwe
bolt-ends made and the securing plates screwed
bolt-end at the housing side
1:16 Models: Kingtiger
1:10 Models: Flak-Panther Coelian, Panther A , S.WS with 3,7cm Flak 37
1:6 Armortek Models: Flak 36 2006, Kingtiger 2013, PAK 43/41 2015, SdKfz 251 2016, FAMO 2018
1:6 other Models: Opel Blitz , Kübelwagen , Zündapp KS750 etc...
Re: Uwe's 88
Incredible! What else can be said? Amazing detailing and fun to watch each post.
Merry Christmas Uwe. :)
Uwe Gerstenmayer
Re: Uwe's 88
Hello Tim,
thx a lot for the nice comments 8) :oops: and from my end as well my very best wishes and a merry christmas :!:
The 88 is really fun to build and as allready mentioned has loads of details which could keep you busy for years :shock: :lol:
I couldn't leave it it like it is so "modified" a bit again :wink: :D
The brackets for the barrel rest (?) have been "adjusted" to look more to the version I'ld like to build :roll:
Christmas Greetings from Cologne,
Uwe
thats what it looks now,  ;-)
brackets lowered and modified, bolts functional made
slots added to the housings and hooks shaped a bit
Paul Wills
Has liked: 646 times
Been liked: 141 times
Re: Uwe's 88
Post by Paul Wills »
Hi Uwe,
Wow, your build just keeps going from strength to strength :D I really do like to your modifications 8) :D
The Snow arrived today, no more high level fell walking till the spring :(
Langdale pikes this afternoon
Merry Christmas from the Lake district :D Paul.
Uwe Gerstenmayer
Re: Uwe's 88
I've been happy to make some progress on the "wheels section" yesterday.
Finaly I could convince my buddy to make my "mandatory tech check" of his Blasting cabine to be fit for 2014 :) :lol:
The results are really nice and i'm quite happy with it :D
We've used a 0,2 - 0,5mm Corund material at 6,0 bar, maybe interesting for those looking for a suitable blasting set-up. The bolts are still in to protect the threads
and mating surfaces :wink:
Attached are some prior and after pics to compare the results :wink:
Best wishes to all and hope you can enjoy as well some days off now with your beloved ones.
Hi Paul,
I'm sure you'll have an idea what to do instead :idea: :lol: :lol:
cheers,
Uwe
The star after the blasting op, like out of the mould, great :-)
The star front before with "some" mods
Trilex star backside finally
Trilex star backside before with some mods
brakedrum out of the box
brakedrum finally after mods and blasting
leesellars
Been liked: 15 times
Re: Uwe's 88
Post by leesellars »
Hello Uwe
On the boggie wheels the arms are cast ones. This is one of the kit alterations that Armortek upgraded. They broke when used. Armortek upgraded them to machined ones.
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Uwe Gerstenmayer
Re: Uwe's 88
Hello Lee,
Thx for the hint ! I'll ask Mark and Gill again early next year for a potential "upgrade-Kit" once the new improved FLAK batch is in production :-) :wink:
For now I'll use the cast ones to come along and make some progress on the boogies...
The last time I've been fiddling around to get the gun rest done. Unspectactular part but I wished to have three hands and a clone beside to help :shock: :D
At the end I won the "solder-battle" and it turned out quite good now :D
Most of the "fun" has been to get the lever function realized :roll: , but thanks to the one who's developed the magnifying glasses it turned out quite good and is working :lol: :D
Uwe
lever closed and aligned :-)
lever open...
lever open...
chains added
chains added
Paul Wills
Re: Uwe's 88
Hi Uwe,
I need glasses all the time and oh yes, come on evolution and grow that third hand :lol: I always feel like that when I solder :roll:
Happy New Year 8)
Paul. :wink:
Uwe Gerstenmayer
Re: Uwe's 88
HAPPY NEW YEAR to all on the forum :D
Hi Paul,
still without the "third hand" I could make some progress on the cruciform bits and pieces again.
The small triangles for the plates have turned out quite risky when you use an elec cutter :shock: One has fallen into the slot of the machine and came back like a shot :shock: :roll: My little fitter has catched it directly and is a bit handicapted now :roll: :shock: Good luck it was not me :wink: :lol:
So the next ones I've made safely by hand, better it is :idea: :lol:
I've attached some pics from what I've made so far ,
cheers,
Uwe
My little "fiddle" E-Box :-)
lower brackets for the springs frt and rear
Hooks and Protection plate for the E-Box
Boogie Hooks and Housing Plates
Boogie Hook mechanism realized
Uwe Gerstenmayer
Re: Uwe's 88
I've made a bit progress again on the cruciform and base details.
On the base I made the "revision-cover" and the grease-port.
I've tried at least to simulate the base-indicator but I'm not that happy for the long term. The smallest I can do is 1,0mm only .. For now the indicator marks will stay like it is, maybe there is later on a Laser alternative on a brass ring possible.. :idea: :wink:
On the cruciform I made one side of the power-brake tubings with all the bits and pieces,
what a "fiddle battle" :shock: :lol:
The proper tools to make the chest have been lost on "Santa's list" :shock: , so I have to look for it myself, soon .... :lol:
The power air connector is not really accurate in scale, good for 1:8 max, but for now at least something which is looking like and functional. :?
Any hint where to get these little "brake-connectors" in correct scale out of brass or similar would be really appreciated :!:
Greetings from the Cologne Area,
Cheers, Uwe
One side ready for the weldlines.....
Tubing connectors made
Indicator Ring, Grease-port and rev-cover made
"brake-connector" like it is now, Plate angle to be adjusted ;-)
Has liked: 1419 times
Been liked: 1594 times
Re: Uwe's 88
Meisterlich :D :D
Been liked: 1644 times
Re: Uwe's 88
very nice uwe, regards simon manning.
Uwe Gerstenmayer
Re: Uwe's 88
Finished today the tubing on the housing side :D
Hello Simon,
I'm afraid when it comes now to the finishing and paint-job, which is for sure not directly my field :oops:
What you guys are doing there on your models is really outstanding and each one a piece of art :shock: 8)
Hi Adrian,
hope this year will turn out better for you !! ( just recalled your "Company-Issue".. )
Uwe
Rolf Mönke
Has liked: 60 times
Been liked: 142 times
Re: Uwe's 88
Post by Rolf Mönke »
Tolle Teile Uwe.....
Greetings from Hamburg
Rolf
bosswilli-hh@gmx.de
Uwe Gerstenmayer
Re: Uwe's 88
Over the last days I've been over the wheels and base again.
I've had the idea to modify a bit my old wood lathe and to use it to work on the tires.
What a mess to grind the rubber tires :shock:
After the last wheel I've been black all over and messed up the whole workshop :lol:
But it's worth, a Flak with tires like fresh from the dealer ??? Nothing for me...
On the outer rims I made the proper fixings and the "protection-plates" for the valves.
The inner rims have been modified a bit with the flat sinks and also the appr fixings.
Waiting for the final paint I will assemble the wheels completely after the paintjob.
On the Indicator ring of the base I've mnade the missing smaller markings. Found a 0,6mm milling cutter so thought to try how it looks like :idea: So congratulations, once started I had to finish the remaining 288 markings :shock: :lol:
Two evenings just milling on my small all manual Proxxon... :roll: :wink:
At the end it has been worth I think, looks now as an indicator at least :D
BTW, the hint on the forum to use WD40 for Alu has been great, works perfectly !
cheers for now,
Uwe
valve protection made and riveted. Overall I'm quite happy now with it
Trilex rims complete now waiting for paint ;-)
flat sinks and bolts made
Indicator Markings completed now
