Page 3 of 4
Re: Smoker Fan Control Unit
Posted: Mon Aug 10, 2015 9:00 pm
by Steve Norris
Hi Adrian.
Good to hear that only one unit is required,
Please let me know how easy it is to wire up on the KT and also pm me with your details for payment.
Posted: Sun Aug 23, 2015 8:27 pm
by John Cooper
Hi Adrian
Could you put me down for 1no smoker fan control please,
John Cooper
Posted: Sun Aug 23, 2015 11:53 pm
Steve, it turns out I did the upgrade to Denny's King Tiger a while ago. Both fans are run through my module with no problems, but I couldn't get into the guts of it to see how they were wired and whether I had to make any changes to the wiring to suit.
Probably best if you could email photos of your current fan wiring to
sales@armortekaddict.uk and I should be able to match up the spade connectors and include any different instructions for you.
John, I have four modules in stock, ready for despatch, so please email me on the address above and I can get your order processed.
Posted: Mon Aug 24, 2015 5:15 pm
by Steve Norris
Hi Adrian.
At the moment I am in the middle of a full rebuild and the smokers are not installed, when I get to the installation stage I will post some shots for you.
Posted: Mon Oct 19, 2015 11:20 pm
by Kevin Tomkinson
hi,
I have seen your post re smoker fan controller and I am interested in buying one if you are still making them. I recently bought a Jagdpanther which has one of these fitted and that has prodded me into getting one for my Tiger 1.Also may be interested in the remodelled fan tops or a complete unit.
Kevin.
Posted: Tue Oct 20, 2015 12:33 pm
by Tim Page
hi, will this work with a 2009 Panther?
I have one of Wiggy's 12v smokers and a Benedini TBS5.
The smoker works well but would be nice if I could hook it up to turn on at engine start.
cheers
Posted: Wed Oct 21, 2015 12:38 am
Following a run of sales at TankMod I'm currently out of stock of these modules
I have done a stock check today and have ordered the additional parts needed for the next batch, so should have them built within a week or so, depend on how work goes.
Tim, I have used one of these with the 12V smoker in a M-1-T JS2 and it works fine.
Posted: Sun Nov 15, 2015 4:56 pm
The new batch of ten units is now built and tested.
Please email me at
sales@armortekaddict.uk with your order requests.
Posted: Sun Nov 15, 2015 5:04 pm
A note about compatibility with current Armortek Amplifier modules.
Recent Amplifier Modules, I believe from the Centurion onwards, are supplied with the TBS Mini sound board rather than the older TBS5 sound board.
- Amp Module with the TBS Mini sound board and adapter
- Amp Module with the TBS5 sound board
If you have the TBS Mini style, a lead needs to be soldered to the adapter board which goes between the Benedini TBS Mini sound card and the Armortek amplifier motherboard.
I can either supply the lead and instructions, for you to solder yourself, or alternatively, I can supply a replacement adapter board with the lead already soldered.
Please check which sound board you have before ordering, to avoid disappointment
Posted: Mon Nov 16, 2015 9:56 pm
Five down, five to go
Posted: Fri Jan 22, 2016 12:32 pm
Still a couple of fan control units available from the last batch, and the next batch of twenty are hot off the (drill) press today:
Posted: Fri Jan 22, 2016 4:15 pm
by Peter Silcock
I'm spotting the odd one out
Posted: Fri Jan 22, 2016 4:32 pm
Bugger
Well spotted
I suppose one hole out of sixty in an unheated workshop isn't bad
Adrian
Posted: Fri Jan 22, 2016 5:17 pm
by Peter Silcock
59 better than I could do! Usual amazing stuff Adrian.
Posted: Fri Jan 22, 2016 6:52 pm
by Steve Stuart
Mr Silcock takes this months award for a sharp eye, I hope that he has not seen my Mark IV as I may find missed rivets next to impossible to fit!
Well spotted! Steve
