Ultimathe Panther by Luca
- Has liked: 161 times
- Been liked: 830 times
Luca,
Your Panther wheels, sprocket and hull are looking really good. Its going to be a masterpiece I can tell. Keep up the great work.
I threaded a few of the track pins, no all of them yet. It is very handy if you need to take the track off to just remove a nut and washer. You may want to Loctite the nuts as they may loosen themselves over time.
Great work,
Great work,
Back again my dears
Just some pics to show my progress. The two rostrum of the rear starter plate come kindly from Steve Norris.
The pics are a bit yellow because I have switched a spotlight but in someone you can see the real color, hope you can enjoy.
If something doesn't sound good please report me
Cya all
Luca
Cya all
Luca
- Has liked: 1480 times
- Been liked: 1686 times
- Been liked: 3 times
- Been liked: 741 times
pictures
Hi Luca,
Maybe you can help me, i wanna look at your pictures of your
panther build but all i see are red crosses instead of a picture,
normaly if i click on the cross the picture comes up but now happens nothing?
regards Yves
regards Yves
- Has liked: 6 times
- Been liked: 807 times
- Has liked: 8 times
- Been liked: 701 times
Hi Luca,
Great job on your Panther. Your exhaust look like an early G but you use the original parts from Armortek. Can you explain because I have seen so many exhaust versions I'm confused
. Is it original to use the bottom part(Armortek) with home made or third party exhaust pipes and covers. I want to change mine to an early model and if this is original I can easily transform my own exhaust.
Stay on tracks
No Marcel, the squared bottom provided in the kit is referred to the middle/late "G" version. The rounded bottom was used commonly in the early "G" version. What's really different from a version to another is the bar retainig the exhaust at the top.
What i have choose (to use the parts provided in the kit over all) is the exaust adopted in the transiction between middle-late version where exhaust's pipe was substitute from the "flamelichter".
Now can't be more specific but later i will post a drawing more explicate.
- Been liked: 1767 times
