M7 Priest
- Has liked: 115 times
- Been liked: 1104 times
Hi David,
Contact Richard at Steel Dragons and see if you can get some Sophisticated Finishes rust treatment. Its a 2 part system like most of these rust coatings and you simply paint on the metal compound and then coat it with the rusting solution. I do add a little paint here and there but no one treatment is ever the same so just work on it till you get an effect you are happy with. As the metal coating is like a thick paint it is also easy to use in crevices and corners and also edges etc.
Dave
Dave
www.armorpax.net
- Been liked: 3 times
Hi All,
Got the basic pulpit made along with the Gun lock. Added one of my M23 mounts but with fixed ammo box and skate rail carriage.
Dave
Dave
www.armorpax.net
- Been liked: 15 times
Hello David
Fantastic work as normal.
lee
lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Hi All,
Added the pulpit, side handles, tie downs and front filler cap.
Back onto the Quad tomorrow so no more M7 till next weekend.
Dave
Dave
www.armorpax.net
Hi All,
Only managed to get a few hours on the M7 this weekend so just the last few brackets on the sides added and some of the welds.
Dave
Dave
www.armorpax.net
Hi All
Got a light coat of Mr. Surfacer on today and the 50 made.
Dave
Dave
www.armorpax.net
- Been liked: 1 time
- Been liked: 177 times
- Has liked: 212 times
- Been liked: 158 times
Hi All,
Its been too hot and close today to do much casting or major constructive work so have tinkered with the M7 between numerous cups of tea and a mid day siesta.
Havn't got much done but did get John Grima's air cleaners and the exhausts mounted. Also made a master for a fibre shell tube as I'm going to need a shed load of ready use and can't afford 38 Dragon Shells sets
Dave
Dave
www.armorpax.net
- Been liked: 14 times
Hi All,
Started casting up some of the Fibre ammo tubes today, pics below.
Fabrice, same style but all different sizes.
Dave
Dave
www.armorpax.net
Hi All,
With all my stock and display packed for W&P not much else I can do so spent the day on the M7. Fitted John's Instrument panel and modified and fitted the first drop down seat. Most of the detailing on the upper engine deck panel is done and a little of the interior wall detailing. Might get a little more done tomorrow before it joins everything else in the van.
Dave
Dave
www.armorpax.net
