- Has liked: 2267 times
- Been liked: 7152 times
Lots more done, I tend to work on many things at the same time, this way paint can be drying while I fettle, fit and assemble other pars.
Phil,
It just gets better and better! I cant wait for the FOA turret interior detailing parts to arrive
I found this photo of a late panzer ( ) turret interior showing the full size periscope in place, So I'm happy.
- NVtdgW-b.jpg (15.67 KiB) Viewed 2394 times
Last edited by Phil Woollard on Mon Sep 02, 2019 8:26 am, edited 2 times in total.
- Has liked: 2508 times
- Been liked: 443 times
Phil, that's the inside of a Panther command tank its not a Tiger
Close though init Mark lol. Mark would you have a nice pic of the internal breech lock that hangs from the roof by any chance, I have this line drawing below but could do with a decent photo so I can fabricate one?
- GunLockProfile1.jpg (17.61 KiB) Viewed 2338 times
I have a disk full of pictures of the Saumur Tiger I will have a look this evening their may be a picture.
Much appreciated Mark!
Thanks Mark that's just the ticket, I think Kent has some competition!
Some more progress on the turret.
- Machining the mantlet pivot mount to reduce the 6 mm gap. Not entirely sure this will work but its a start, removing the front portion of the pivot mount will bring the mantlet back without causing any knock on effects, it will of course reduce the forward weight of the pivot.
I may need to remove more material but am being cautious as I go.
- Has liked: 775 times
- Been liked: 1741 times
That's a big milling machine you have there Phil. Looks like a Bridgeport clone. Will be interested to see the end result.
- Has liked: 6 times
- Been liked: 194 times
Phil Woollard wrote: ↑Mon Sep 02, 2019 7:56 amThanks Mark that's just the ticket, I think Kent has some competition!
Found an interesting Henchel factory drawing at Panzerbasics from the Per Sonnervik collection that might be of interest regarding the mantle/hatch issue. It looks as there was a bit of problem in 1:1 or at least on VK45.01 but I dont think it was any changes here later in the Tiger1 production.
It´s all in the details!
Thanks Kent, that drawing seems to show a 1.1 interference/protrusion over the hatches, now that along with the large mantlet gap and we have a bigger interference issue.
Hi Vince, yes that a serious bit of kit as far as modeling goes! I have had to ask a local engineering company to do the work as it need to be right.
I have just assembled the unit and I think it looks ok, any tighter and the pivot angles on the turret may be a problem. That's just 3.5 mm removed, care being taken as the pivot mount was 12 thou thicker at one end before we started, so around 4 mm in total . I will post photos tomorrow.
The turret.
Also love how the rifling insert looks.
Guess what I have been so quiet about?
