OPEN ON THE 6TH FEB 2025
Has liked: 2267 times
Been liked: 7152 times
I will check for any flexing of the rear deck once the turret is fitted, I can then decide if it's feasible.
The armortek pivot nut really needs hiding altogether! The dome only hides the protruding thread, and I don't really like the look.
This is how the idler assembly should look, I was thinking of using the dome head m4 on the idler pivot not the adjuster bolt.
Been liked: 1793 times
It's a difficult call on the nut, I'm not making any changes to the suspension, support or drive systems. Armortek have far more knowledge than I'll ever have.
It might be possible to hide the nut with a small cowling cover, recessing just weakens the block, It depends how far you need to go.
When you polished the rear gearbox bearing hub I wondered can you actually see the hub when the sprocket and track has been fitted.
Even now I'm thinking should I or shouldn't polish the hubs up. The gearbox housing is "sort of" the right shape and so are the detail parts I made. I may leave it like that.
John you do what you feels suits you, and what you are happy to live with. I may even go back over some areas as I research and find even more relevant detail! Yours is looking great all ready. Boy we have a long ways to go yet! 8) I think I will turn some covers for that idler nut, or will never sleep tonight.
Wish I was as far forward as yourself, I look forward to having the hull on it's tracks, then the fun really starts.
Trying new stuff is part and parcel of the hobby and your a master of it. :mrgreen:
I put one suspension unit together the other night not realizing the spring unit falls out unless the swing arms put pressure on it. Which they won't as there's no hub, wheel or track to hold it all together. Still it does allow the completion of the spring units once painted. An elastic band holds it together at the moment.
By the way the 1:5 Chieftain suffered from scuffing of the rear gearbox housing so keeping the tracks taut is a must, though you won't be able to get your fist between track and mudguard. :D
The bigger parts cleanup and priming, and they are big! John if you tighten the m8 bolts for the swing arms they will stay in place and so hold the springs while you work on the rest of the suspension unit. Then loosen the bolts after fitting the assembly. 8)
That lovely T plate which currently sits on top of the rear deck.
Not a bad fit of the bigger parts at all.
Thanks for the tip on the suspension units Phil.
Will you be leaving the rear deck loose for access to the drive motors gearboxes or is it possible to mount them with the rear end buttoned up.
I've got hold of some 8mm half nut nyloc's, which work well with the suspension units and should be useful on the idler front mounting blocks. Allowing for a shorter sleeve to cover the nut.
I want to have the T plate removable if at all possible so that the pack bay can be opened up like the 1/1 example, then there is plenty of room to get to the motors. I need to assemble all those god dam deck vents first, I am dreading that job but it must be done very soon so I can plan all the deck plate modifications. 8)
This photo again!
This photo again!
I'm back on the case 8) first photo detailing the first of the hull side fitting s using only hand tools.
Using a hacksaw and file to create the extra detail to the long fitting.
Adding the tiny bolt head detail to the pressure fitting.
The fitting in place.
On to the big casting extra fixings. That's an m4 drilled through the fender to pull that part up to and tight to the big casting.
All nice and level and in line and neat.
Fitting the Tricky to get at big casting to fender mounts , I have used m3 lock nuts on the out side so it looks tidy if the vehicle has the bazooka plates removed.
Very long m3 in place.
I've been cleaning up and test fitting some of the bigger parts. I still haven't started on those louvers yet. 8) That turret rotates effortlessly with just one finger.
I am having to use a handraulic wire brush as the turret is just to heavy now to hold up to the machine for power brushing.
Pick up truck.
Pick up truck.
The idlers are in place now and are working beautifully.
It is all going together nicely with the help of my rubber mallet.
I do like the look.
I do like the look.
We have a few divots in the casting, now do we fill them or are they like the original? Stephen your opinion please?
Just how much do we need to clean the sand casting marks up, what's acceptable?
Steve Ellis
Has liked: 34 times
Been liked: 26 times
Post by Steve Ellis »
Hi Phil
Been following your build with keen interest, your doing a grand job.
To answer your question regarding the texture of the turret I would leave it as it is.
I served on Chieftain for 13 years, all the surfaces had a gritted anti slip texture on them including the bins.
Hope this helps.
Starting to look pretty Phil, although I'm sure the casting chap must have had the dropsy's with your turret. :lol:
Though I haven't put any paint near mine yet, so they may show up then. :oops:
There's a crease effect in the casting that I'm sure needs flattening out, see picture. I cannot remember seeing it during clambering over the turret years ago. if it is supposed to be there please shout out :shock:
I'm going to try and leave the sand cast effect too, if not a little down graded once the etch primer goes on. I like the casting effect and have not tried to remove it anywhere where it does not impede against anything else. Other detailed work like the little openings for the emergency sight and other tiny things bring the turret to life.
I was also toying with the idea of magnets instead of screws to hold the turret roof down for easy access.
Has liked: 1024 times
Been liked: 2094 times
Phil, as Steve says, it's fine as is. The turret and some areas of the hull had an anti-slip applied after casting. There is a drawing listed to define the areas on which the paint was applied but I don't sadly have a copy. This shows it was factory applied, to a standard pattern.
I did a post on it somewhere with some photos but can't find it.
These might help:
Guys, Steve, John and Stephen thank you all so much for this valuable info, your input is great for all those building this complex monster. There is so much to learn, so much extra detail, every time I look at at another photo that's posted I can see tons more detail that I have never been able to see before. This is a very enjoyable build and a very steep learning curve! 8)
After dry fitting the parts are further cleaned up and etch primed.
Etching all the way, it's evil stuff but it sticks like nothing else.
I do like cleaning up these parts and adding my own texture to the ali.
I love this casting, some work went into that!
To get this level of fit takes a bit of fetling but we'll worth the effort.
Some work required here.
These will need to come off once more and detailed further, much further.
Richard Goodwin
Has liked: 294 times
Been liked: 291 times
Post by Richard Goodwin »
Stephen White wrote:
Sun Nov 24, 2019 11:01 am
These might help:
Phil, my apologies for capturing your thread but Stephen, would you happen to have any more pictures of the turret which clearly shows the Stillbrew armour? In particular, the side where the ATU is located?
Once again, apologies Phil!
