OPEN ON THE 6TH FEB 2025
Has liked: 2267 times
Been liked: 7152 times
The rear box will need a fair bit of work if you are fussy. I am currently trying the barrel clamp always but may put it back up a tad and the other way round 8)
You don't have to do any of it
Things need moving to get it all to work. The barrel clamp is not in the correct orientation at present.
Been liked: 1793 times
What a wonderful job you've made of the rear end exhaust box, the extra fasteners really set it off.
I have had my reservations on the telephone coms box for being some what "loose", but the extra face and back plate set it off quite nicely.
For me, Jury's still out on the tracks. :D
The coms plumbing, well some of it, still have around 10 more tiny conduit brackets to make and some double cable runs under the rear box to complete. Then some big, as in full size weld runs and we can move on. The large and small exhausts and flanges are also needed to complete the look. 8)
Thanks John, this area is so important for the look we are after. You will get the tracks just be patient! 8)
That's about it for the rear box detail.
All the junction boxes and the coms switch have been made and are bolted on. It's starting to get busy , the detail that is. The more you look the more you see.
Just need to link the junction boxes together and we are nearly done here.
Please note guys that my email has changed ( a second party was buggering around with my accounts!)
It's now
Philandkris2@hotmail.com
It is also on the signature at the bottom of every post as normal.
Bellying out was a big problem, Salisbury Plain was notorious for this especially in the chalkland valleys, as you traversed the hills the top soil was only around 300 mm deep so wasn't so much of a problem. I don't think this photo is SPTA. As you guys are well aware if at all possible you stay in the valley, or at least away from the ridge so that you don't produce a visible silhouette, only cresting the ridge to engage, fire and pull back down the slope, watching the battle group during an exercise preforming these manoeuvres can seem very long winded but you have to appreciate the tactics in armoured warfare.
Moving on. 8)
Some of these drawings might seem a bit daunting but just use the open circle, tick that circle when you have correctly identified the parts and just work your way methodically through the page cross those ticks when that part has been fitted.
Laying out the bigger parts as it's all new to me .
Crapy photo showing the conduits in place.
It's poring with rain and blowing a storm, I'm nice and snug in the tankshop having a good day 8)
More later.
andymusgrove
Has liked: 192 times
Been liked: 89 times
Post by andymusgrove »
Hi Phil
You really are cracking on well :D
Can i ask What do you use for your Cable Trunking please
Andy
Hi Andy, it's just malleable tying wire 2mm diameter. It's the tiny brackets that are so fidley !
Now onto the front casting, you guys are gonna have fun with getting this to fit, best leave the hull fixings loose or just nipped up so that the hull width can move a bit. If you don't know what witness marks are then you will struggle. Put simply they are the contact evidence that's shows you where the material needs to be removed. So clean the casting up and fit and file until it drops in, you will need a rubber mallet to get it to drop in!.
The front plate also needed a fair bit of material removing from the mating edge, if you are familiar with say woodwork joints or even stone masonary, you will understand that the front edge that can be seen needs to be a perfect fit ,to achieve this only that edge needs to touch the mating surface, the back section of that surface can be chamfered a few thou to allow the front to contact. It's a lot less work than having a full thickness perfect joint.
Leave the fixings just nipped, that's all the hull sections that need to be able to move as you get this dirty great big lump to fit.
I've used hex heads for the side skirt fixings as the owner may want to show the vehicle without the bazooka plates attached.
I reckon this area on the final drive casting is going to receive considerable wear.
There's been a bit of a mix up with the idler shafts, and it looks like those sent out to me have been lost by are bl..dy postal service! I guess these things happen.
Been liked: 1651 times
Good build thread to follow, even though i dont have a Chieftain, a complex Tank to make, real or 1/6, Heavy Armor, regards simon manning.
I'm looking for some decent photos of the upper deck plate welds either side of the engine covers, also the fender/armour fillet piece, the engine deck centre plates that supports the hatch louvers and how that bolts on. I have big plans for the engine deck but reference material is sparse!
I could do with finding a Chieftain near me that I could go along and maybe photograph the odd detail, anyone know of a vehicle nr Plymouth? 8)
The fillet piece is that bottom edge welded?
That centre piece looks to be bolted?
th (14).jpeg (36.91 KiB) Viewed 1801 times
You can see where the centre piece bolts to.
The fillet piece detail needs adding.
Guess what I have been doing?
Also made some temporary idler shafts from some horrible m10 gate bolts, temporary mind as I'm sure armortek are on the case!
First key coat going on
Proper paint too.
Proper paint too.
Not bad coverage from an air pen.
michael hilton
Has liked: 1564 times
Been liked: 835 times
Post by michael hilton »
Love your work Phil, brings me down to ground level , and some normality :wink: I do not need stress at my age, I should be handled with care....or in a care home 8) ..Mick
I feel sad when you are sad Mick! Poor ol Ivano is sad to as the lab that will be producing the L60 motor castings are caught up in the flooding around Venice right now!
On another note that cross piece on the engine deck is called the "T piece" so I can now confidently cut things about so that the part can be removed just like the original.
Plodding on even on the day of our Lord.
Not sure about the dome head m8, what do you guys think?
Some of these fittings need placing now as they are fixed from the back of the big casting before it's permanently bolted in place, others are threaded and so can be fixed from the top.
Looks Great Phil 8) I prefer the threads showing on the track tensioner's and flush fit bolt nut.
Can I ask if your going to add support to the rear hull deck when you remove the "Tee section". I had considered doing this myself for better access, but as there is little support for the turret at the rear thought better of it, though I am considering a little structure improvement under the rear turret ring anyway.
The weight of the turret is ....Heavy. And although the front upper hull casting supports the turret ring well, the rear is only lightly supported by the rear deck. This maybe ok with the gun pointing forward with the weight at the front. But I'm guessing transport will have the gun facing to the rear, gun split or no split.
I have looked at some old pictures of a 1:5 Chieftain I once owned which had a removable "Tee section". It had extra cross members, thicker rear deck support material for a turret that weighed half as much as that of the Armortek Chieftain.
Do you think there's enough support for the turret ring bearing?.
Old 1:5 Chieftain pictures.
SAM_0707 ring.jpg (202.92 KiB) Viewed 1642 times
