Pz III New Build
Has liked: 126 times
Been liked: 755 times
Stephen your detailing is starting to really pay off. Great looking hull! Its going to be a fantastic model when finished. Thanks for posting.
Has liked: 1024 times
Been liked: 2093 times
Catwalks
Finished the catwalks today with the anti-slip mesh rivetted as Jeff has done with one sixteenth copper rivets. Even they look a bit big but the overall effect seems OK.
Catwalk brackets
Made a start today on making the extra bracket for the rear end of the catwalks.
No visible means of support, wonderful what bluetack will do.
Has liked: 1371 times
Been liked: 1567 times
:lol: :lol:
Nice looking bracket :D
Front catwalk supports
First day in the workshop for a couple of weeks. There's been so much inspired use of brass parts on the forum that I thought I ought to have a go:
These are the front catwalk supports which are functional:
I followed a tip of Mike Stannards and got some Solder-it paste from the States.
It's certainly easy to use but I'm not wholly convinced, the joins seem to be a bit hit or miss. Maybe that's just a question of getting used to it. I reverted to Baker's and silver solder for the main joint.
The supports installed:
Also added the small brackets on the upper hull:
Just waiting for my piano hinges from Belair before doing the front and rear mudflaps.
Bradley A Smith
Post by Bradley A Smith »
Hi Stephen, looking great, did you say you dropped the front and or back cat walk supports down a few mm.
possum
Have a nice day
Possum
AKA Brad
Bradley, looking back, I don't think I ever posted the changes in height so here goes (bearing in mind I'm using Steve Winstone's excellent brackets):
The back and two centre brackets should be 9mm heigher that the original setting. The front bracket should be 7mm lower that the other three. The additional supports at the very front and back have to be set according to drawings (I used the Panzer Tracts ones) to give the characteristic drooped effect. Hope that makes sense.
All the best.
Looking superb Stephen 8) Great job on the fender brackets and rivets.
Rear catwalks
Detailed the rear catwalks today, ie the moveable section. Added the lip, a hinge doubler and the fixed portion underneath. It took forever to fit, to get the right angles.
You don't have to be mad but it helps.......
I wasn't happy with the one sixteenth round head rivets which I used to attach the anti-slip surface to the catwalks - on the original, the rivets are barely noticeable and these looked like the domes at the Eden Project.
So I ordered some 3/64th from EKP and trial fitted one. Despite the now oversized hole, it worked. Bad news. So now, I've removed all 200 or so and replaced them. Still, I might otherwise have been making progress.
Made a start on the front mudguards by filling in the detents in the original and adding the reinforcing strip.
My Pz III will be ready for the Open Day - I'm just not sure which year.
Been liked: 1634 times
quality build, informative, interesting,all the ingredients which make it a must follow construction, plenty to follow on these panzer 111 threads,,keep the posts coming stephen. simon manning.
Thanks Simon
Detailing of the front mudguards completed, together with new rivets. Support stay for the rear mudguard added (Jeff, noticed you'd done it as well).
Next to tackle the quite complicated metalwork supporting the front mudquards on the hull sides.
Completed the metal work supporting the front mudguards.
Original:
Model:
Haubenhalter x 4
Finishing off the front mudguards, I've added the two retaining latches, fabricated from brass and a shaped piece of ally - yes, soldering them provided hours of entertainment.
The Armortek rear mudguards lack the inner flange, so there is nowhere to mount the rear latches. Next job to remove the mudguards, fabricate a flange and solder in on. Something about time spent in reconaissance.......
Sarah Frazer
Been liked: 2 times
Post by Sarah Frazer »
Hi Stephen,
We are all appreciative of your reconnaissance work :D
Keep up the good work.
Sarah
