Mr Dawe's Centurion.
Has liked: 2259 times
Been liked: 7147 times
Re: Mr Dawe's Centurion.
Yeah that reference kit was way out man.
Time for an interim stock check/look see of the model so far.
Bazooka plate hanging claws, this is an early mk but were they all hung like this?
How about these weathering examples?
Adding interest like previous weld witness marks, these models have large open sections with not much going on so this kind of detail breaks it up a little.
One for Mutley, I want to add your DMS melted sole imprint on one of the exhaust shields but I can't find a British boot to make it!
Nice example of adding a little interest? The stiffener piece has been moved at some point ( probably after some damage repair ) but the weld witness marks are left showing. The old weld has been ground off but the arc penetration cavities are untouched.
Those claws I was referring to.
Not much tactical/use wear but a good deal of the environment! This has had some thought put into it, it's very difficult to get this to look right in scale. I bet Simon could replicate it.
Or this example? Lots of "rubbing" marks on the bazooka plates?
Dem bazookie plate arms, one side is finished.
Decided to solder the hull end joint.
Ali solder is strange stuff, it doesn't flow you have to wipe it on.
It's extremely strong but as it doesn't flow you have to work from all sides.
Don't know how that got there.
Steve Lewington
Has liked: 8467 times
Been liked: 277 times
Post by Steve Lewington »
Hi Phil
You don't need a DMS boot print just a boot shape of melted rubber bud.
Sargent keep awsy from the exhaust son it gets fxxxxxx hot.
Me yup no problem sarge.
Two minutes latter opps left boot knackered got a P1954 for a new pair of boots.
Sargent xxxxxxx ccfdc ect now our breakfast is going to stink of rubber.
My bad 😆
Muttley
Last edited by Steve Lewington on Tue May 17, 2022 7:55 pm, edited 1 time in total.
There is no time for peace.
No respite.
No forgiveness.
There is only ......WAR.
Has liked: 1363 times
Been liked: 1563 times
Very nice but I could buy a full size pair of dms boots for £20 quid!
The claws this afternoon.
Just the same as the real thing.
The claw mounts silver soldered in position.
Once I have finished with the milling vice I can then machine these bolt hole slots.
This photo is for Dave Dibb, these tie downs or very similar for the bazooka plates.
Phil Dawe
Has liked: 754 times
Been liked: 276 times
Post by Phil Dawe »
Phil, those claws are brilliant. Keep up the good work. :D
For Dave Dibb while you have got your parts hat on.
Do you have anything in stock for our kit lockers shown in this lovely old photo Dave?
The petrol cooker would be great.
Finished the off side bazooka plate arms at last and I'm still working my way through the bazooka plates.
Moving along steadily.
The kit fender support brackets need lots of work, they are to short, they have gaps in them and not enough fixing holes
Silver solder.
Silver solder.
Luckily I had some spare brackets to cut the section from.
It may look a straight forward job but it's actually a bugger.
Don't know what I would do without my power file sometimes
You have to adjust everything to get them to line up.
I think this guy is sending a message, I think he's saying love to all mankind.
Chang
Has liked: 15804 times
Been liked: 424 times
Post by Chang »
"I think this guy is sending a message, I think he's saying love to all mankind."
Is it just me, or everybody thought this guy is YOU...... :-D
The near side now. While the paint is curing I'm seeing what can be done with the tools on the off side infantry rides.
Bazooka plate standoff brackets now all complete.
Tapping the bazooka plate fixing holes.
That's one of my new parallels being used as a heat sink!
More of that silver soldering
Nice fit.
Nice fit.
See what I can do with the recovery ropes.
The double shovel look.
Phil with the double shovel handles held this way round it's more in keeping.
I've weathered this side exhaust shields
Phil Dawe
Post by Phil Dawe »
Does anyone know whether the convoy stripes on the rear deflector plate is illuminated by a lamp?
Chang
Post by Chang »
Hi Phil,
What is the title of the book with plenty of photos above the model? Can you show us the front cover page? Thanks in advance.
Lerh Chang
Has liked: 1023 times
Been liked: 2093 times
Chang:
Sometimes seen second hand.
Phils:
