My Stug conversion
- Been liked: 2 times
- Has liked: 219 times
- Been liked: 199 times
- Been liked: 177 times
Hi Guys
After a year it seemed to be time to get back to the Stug,
One of the issues I had was the gun swivel was to difficult to control so I
have rewired that to the elevation side of the control so I can use the micro switches to limit the movement.
The next picture show the electrics installed at the rear of the stug.
As you can see I have a simple lift off rear deck and everything is under it.
the roof is bolted down and is a pain to take off I am going to make some changes to this to make it quick release.
Nice to be back posting
- Has liked: 155 times
- Been liked: 822 times
Re: My Stug conversion
Hi Guys
Ready for the open day I have been busy finishing off the paint work and cammo
so it will have its first public showing in this form tomorrow.
I will hope to get some photos of the finished thing at the open day and post them here next week.
Hi Guys
As promised some photos of my stug at the open day in its finished camo.
Nearly all done ready to start on the Comet
- Been liked: 1756 times
i had a good look at the open day derek, very nice indeed, it is in its own catagory as a build, an outstanding model wish i had one. regards simon manning.
Hi Derek
Excellent photos. Thank you for sharing. As Simon said, in a category by itself.
best regards
best regards
Hello Derek
It,s good to see it with its camo on very nice ,congratulations on a superb build
regards
nick
regards
nick
Hi Guys
I am going to be at Ally Palace with the Stug again this year I will be down by the
Rose window end as last year.
One of the things I get asked a lot is what was the tank like before
the conversion so I am building the turret and the upper hull as a
side display.
I am also going to leave it unpainted so people can see the materials used and
how the models are put together.
I started today and built the hull sections and the deck but found the turret will need a lot of fitting to get it together.
The rear panel seems to be over bent. Is that something others have found ?
I am sure I can sort it. This will be out of the box build only.
side display.
- Has liked: 1473 times
- Been liked: 1667 times
The Panzer III turret will take a long of fiddling to get it all lined up.
Probably best to get every bolt through, even if very loosely, then ease the panels into place and tighten once they are aligned.
The Panzer III I purchased second hand had had one of the lower mounting holes extended by around 1/4", in order to the screws to line up with the hole in the base plate.
- Been liked: 15 times
Hello Chaps
I have built 4 now and none of the turrets fitted correctly first time alot of new holes and redrilling and Tapping.
Lee
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
