sdkfz 7 build log.
- Been liked: 1643 times
Re: sdkfz 7 build log.
Thanks Jeff, coming from the Master. Just a bit more paint added, i am having a well used, multi layer colour scheme on this 7, no monotone pallet, regards simon.
- thumbnail_IMG_9591.jpg (121.39 KiB) Viewed 4850 times
- thumbnail_IMG_9588.jpg (122.35 KiB) Viewed 4850 times
- thumbnail_IMG_9587.jpg (137.88 KiB) Viewed 4850 times
I have finely assembled the 7 body panels, it has been a challenge making it all fit, still some tweaks, pulling and pushing, Filling, i feel i am on the Home straight now, The last big wrestling match will be the Hood and blending all the paint scheme in, regards simon.
- thumbnail_IMG_9623.jpg (99.97 KiB) Viewed 4790 times
- thumbnail_IMG_9620.jpg (99.69 KiB) Viewed 4790 times
- thumbnail_IMG_9617.jpg (113.64 KiB) Viewed 4790 times
- William Gardeniers
- Has liked: 45 times
- Been liked: 280 times
Thank you William, After many hours of fitting and adjusting i Have finally started on the paint finish on this side, just an undercoat of a darkened red oxide with an overlay of weak colour and a few rust streaks that will show through the top layer of finish, i am pleased to be at this stage, regards simon.
- thumbnail_IMG_9641.jpg (134.35 KiB) Viewed 4679 times
- thumbnail_IMG_9640.jpg (163.1 KiB) Viewed 4679 times
- thumbnail_IMG_9638.jpg (140.68 KiB) Viewed 4679 times
Just some more progress on the 7, This Vehicle will take me a good while to paint, not every ones taste but i like the worn out, used look, regards simon.
- thumbnail_IMG_9652 (1).jpg (139.79 KiB) Viewed 4630 times
- thumbnail_IMG_9648.jpg (126.48 KiB) Viewed 4630 times
- thumbnail_IMG_9646.jpg (141.73 KiB) Viewed 4630 times
- thumbnail_IMG_9642 (1).jpg (103.84 KiB) Viewed 4630 times
- Has liked: 2267 times
- Been liked: 7152 times
Certainly the worn out look, it will be interesting to see the finished result which will no doubt be spectacular!
Thanks Phil, its the bit i like the most, painting that is, i moved on around to the the rear, this is just getting the colour on then i will add some more detail, all for now, regards simon.
- thumbnail_IMG_9671.jpg (145.88 KiB) Viewed 4548 times
- thumbnail_IMG_9670.jpg (140.3 KiB) Viewed 4548 times
- thumbnail_IMG_9667 (1).jpg (148.32 KiB) Viewed 4548 times
- Has liked: 20 times
- Been liked: 737 times
Thanks for the encouragement jeff, I have fitted the rear Mudflaps which i made over a year ago and continued painting the 7, lots of little jobs finished also, rear light fitment etc, all for now regards simon.
- thumbnail_IMG_9705.jpg (130.15 KiB) Viewed 4443 times
- thumbnail_IMG_9698.jpg (158.4 KiB) Viewed 4443 times
- thumbnail_IMG_9695.jpg (144.61 KiB) Viewed 4443 times
- thumbnail_IMG_9694.jpg (141.64 KiB) Viewed 4443 times
- thumbnail_IMG_9693.jpg (146.21 KiB) Viewed 4443 times
- Heiko Sattler
- Been liked: 535 times
very impressive building report. i love your sdkfz 7 special this fucked up look i can't get enough. there are not many people who can play with color so well to achieve such a look
Thanks for the post Heiko, i have been working on the lights and finally have them all working with an independent on-off switch from the motion pack, i like to keep it simple. regards simon.
- thumbnail_IMG_9768.jpg (142.04 KiB) Viewed 4269 times
- thumbnail_IMG_9767.jpg (134.62 KiB) Viewed 4269 times
- thumbnail_IMG_9763.jpg (115.85 KiB) Viewed 4269 times
- thumbnail_IMG_9756.jpg (95.71 KiB) Viewed 4269 times
I have just started to fit the Michael Matata hood/ roof, This item is the work of a genius model maker, it is very intricate and well made and fits very nicely, you have to adjust a few items and make your own brackets, i also finished drivers / passenger side front floor panels which was a little tricky, still lots of jobs yet to finish, regards simon.
- thumbnail_IMG_9792.jpg (66.29 KiB) Viewed 4200 times
- thumbnail_IMG_9793.jpg (99.59 KiB) Viewed 4200 times
- thumbnail_IMG_9794.jpg (93.5 KiB) Viewed 4200 times
- thumbnail_IMG_9790.jpg (84.65 KiB) Viewed 4200 times
- thumbnail_IMG_9787.jpg (90.32 KiB) Viewed 4200 times
- thumbnail_IMG_9784.jpg (72.48 KiB) Viewed 4200 times
- Has liked: 753 times
- Been liked: 1772 times
Hi Simon
Superb detail, it looks very realistic.
Gary
Gary
- Has liked: 26 times
- Been liked: 193 times
Brilliant work, in a different setting your work would look full scale.
Have you considered making a training video of your techniques? I am sure people would want to study one.
