A 47 years old love
Frank Breitenbach
Has liked: 54 times
Been liked: 689 times
Re: A 47 years old love
Post by Frank Breitenbach »
Hello at all
The electric power supply for the searchlight. Only for one or two times per year, a Hand Switch is ok for me.
All the best
Frank
Last edited by Frank Breitenbach on Fri Mar 12, 2021 8:30 am, edited 1 time in total.
Derek Attree
Has liked: 219 times
Been liked: 200 times
Post by Derek Attree »
Hi Frank
Pictures back well done Armortek, Not sure why it was only affecting franks posts though
as rest of forum is fine.
Frank Breitenbach
Has liked: 54 times
Hello at all
This is the last outside part.
Many thanks Stephen. You building report was very helpful for me and a great inspiration!
All the best
Frank
Frank Breitenbach
Has liked: 54 times
Hello at all
Now my first free hand painted mark.
Frank
Christoffer Ahlfors
Has liked: 746 times
Been liked: 359 times
Post by Christoffer Ahlfors »
Stunning model, to say the least! :D
I particularly like the oil stain and wear on the dozer blade. The model would do well in the "real or fake" section! :D
Frank Breitenbach
Has liked: 54 times
Hello at all
Hello Christoffer, many thanks.
Now the first Chinese eye, also free Hand painted.
Frank
Frank Breitenbach
Has liked: 54 times
Hello at all
Maintenance - Optimize the sound, will put the micro SD cart in the slot…big fingers….micro SD card in the cellar of the model.
All the best
Frank
Günter Gäbelein
Has liked: 41 times
Been liked: 195 times
Post by Günter Gäbelein »
Hi Frank,
:lol: :lol: :lol: lift up the model turn it upside down and shake will not work. Take the vacuum cleaner with a socket over the entry :wink:
Günter
Has liked: 1480 times
Been liked: 1686 times
Sorry to hear that :oops: :oops: :oops:
Quicker to buy another SD card I think :wink:
Leave it as an archaeological find for the future.
Frank Breitenbach
Has liked: 54 times
Hello at all
I like to build the engine compartment.
That I can find the right dimensions, I need some real sizes. I know that the cylinder bore is 137,4 mm.
If someone know the desistence from bore tot bore, please let me know. It would be very helpful!
If you know other sizes, please let me know.
Hello Adrian
I had found the SD cart direct beneath the sound box.
All the best
Frank
Chris Hall
Has liked: 535 times
Been liked: 686 times
Post by Chris Hall »
Frank -
I have a reprint of the Royal Armoured Corp's User Handbook for the Centurion Mark 3, originally published in 1953. Does that cover your build ? (given that many Mark 3's were upgraded to Mark 5's). If so, I can PM you some scans of both the technical numbers and the engine layout.
Incidentally, it has the cylinder bore as 137.17mm for a Meteor Mk. 4B engine.. 12 cylinders, in two banks with a 60 degree Vee.
Hope this helps, and stay well,
Frank Breitenbach
Has liked: 54 times
Hello at all
The next part: The track tool box (I hope it is right).
Frank
Has liked: 1038 times
Frank, if you mean the bin on the glacis plate, it was for stowage of a hood for the driver which kept the worst of the rain and spray from blinding him when driving opened up. It was very rarely used.
Frank Breitenbach
Has liked: 54 times
Tank you Stephen.
Frank
Frank Breitenbach
Has liked: 54 times
Hello at all
The first steps to the engine compartment.
Frank
