My Stug conversion
- Has liked: 219 times
- Been liked: 198 times
Hi David
It is a celelose mix from an auto suppliers in the UK
They matched for me from a lightened Tamyia desert or dark yellow pot
with extra white added to about 10 per cent.
I painted some on a section of primered alloy and then they matched it.
I had it mixed for the Panther and there was a load left so I have used it on my Stug.
I am happy with the shade.
So Guys and Girls.
Went to Wings and Wheels with Robin and others form the Tank club.
Very hot both days and I had the Stug with its first proper run.
I have not got the cammo done but I have added some new parts like the gun cleaning rods here are some photos.
Hope you enjoy
Hope you enjoy
Hi Guys
I had a problem while running at Wings an Wheels I had the Stug on 40 meg radio (Futaba) with the new motion pack.
When running forward in a straight line pushing both sticks forward the stug took off in a large ark.
We then changed the the two receiver leads for speed control and with the sticks fully forward the stug took off in an ark to the other direction.
I think there is a miss match in the speed control board. I wonder is there some setting on the speed control.
Please note all trims were in neutral.
Should the new motor pack work with all types of radio not just 2.4 meg sets.?
I have bought a 2.4 Futaba 7C set for other reasons which I will fit but I would like to understand this problem.
The tank is really smooth running on its tracks and I am very happy over all.
- Has liked: 1470 times
- Been liked: 1642 times
I would have thought that pointed the finger at the transmitter/receiver rather than the speed control board.
Do you have a spare servo you could attach to each channel in turn and see if you get the same deflection from each of the channels on the receiver, when the stick is pushed fully forward ?
The 6EX range have a "factory reset" facility of each model stored so that you clear any strange settings for that model.
- Been liked: 3 times
- Been liked: 472 times
- Been liked: 2 times
Hi Derek,
The Stug looks brilliant, having the base coat a little lighter is a good thing as it will definitely darken up when any weathering or other paint effects are added.
As Adrian says, it does sound like the problem is with the radio gear and with one channel. I'm not sure, but can the steering trims affect the end points? It might also be worthwhile checking the end point adjustments as this could affect it as well. You could try setting it up again from a spare model memory.
I'm looking forward to seeing it at the Armortek open day.
Sarah
Sarah
stug111
Hello derek
sorry carnt help with the track problem ,but would just like to say how mutch i like your stug it is a favourite of mine well done ,carnt wait to see it with camo on it ,and i would like to see a side profile picture as well.
best wishes
nick
p s
if mark and gill decided to make a universal chasis for the pz111
i would like a stug upper hull. HINT HINT
best wishes
nick
p s
- Been liked: 1732 times
Hi Derek,
A friend sent me this link to a Stug site which I've not seen before.
http://www.dishmodels.ru/wshow.htm?p=138
Are you getting any time on your Stug?
Sarah
Sarah
Hi Sarah
Thanks for the link ,
No I have not looked at the Stug since
Wings and Wheels I am moving on the 30th so the workshop is all in boxes at the moment and the models go into secure storage tomorrow night so I don't have to move them on the day.
I have bought a 7C radio on 2.4 so that should sort out the speed differences
on the drive motors. as you can tune the ratios on the handset.
I am going to War and Piece Thursday and Friday to have a look round
No Stug though.
No Stug though.
