Mr Dawe's Centurion.
- Has liked: 2259 times
- Been liked: 7149 times
Re: Mr Dawe's Centurion.
Michael would you have any good reference photos/ drawings of the infantry telephone and the tow rope bollard and associated rear plate area please?
- Has liked: 73 times
- Been liked: 109 times
Phil,
I've had a look through my Centurion images this morning, and the vast majority have the rear fuel tank installed with the telephone on the side of the fuel tank. Other than grainy B&W taken in the 1950s and early 1960s, I have a couple of colour images of tanks without the rear fuel tank which I will have to scan.
The best Tank Telephone image I have is below. It is the Australian modified position on the side of the fuel tank, but still provides a reasonable overview of the telephone box. When mounted on the rear plate, it was upright, ie rotated 90 degrees right of the shown position
If you PM me your email, I can send a higher resolution image of the one below, plus the other two mentioned above.
Mike
Mike
That looks good Michael, my email exploration20@outlook.com.
- Has liked: 1023 times
- Been liked: 2093 times
There are a stack of pics and drawings for the inf/tk telephone on my Cent thread here, although it’s for the Mk 5/1 with external tank. The box was common to all marks though.
viewtopic.php?f=23&t=3931&start=465
And if you feel it needs the ‘phone itself, details here:
viewtopic.php?f=23&t=3931&start=480
I never met an infantryman brave or stupid enough to use it.
The Chieftain also had the very same unit, Stephen would you be so kind as to let us have the Length, width and depth of the unit please?
I looked ta. On with the infantry telephone unit, fiddly work in steel but satisfying
Finished the infantry telephone unit, lots of work and no where near as detailed as Stephens!
The arse is now complete, on to the gun crutch next.
Have a look at the new taller deflector brackets Phil.
A couple more photos of the real thing for reference.
I may make some mid way brackets and try those.
- Very steep angle on this example well below the towing lugs
- 9289570999_3c7d0dcbfa_c.jpg (120.75 KiB) Viewed 1259 times
- A bit bent this one!
- 1385125518-centurion_mk_5_12_of_91.jpg (63.67 KiB) Viewed 1259 times
Gun crotch/crutch sorted this afternoon.
