And I found an unexpected problem.
It was the fact that interference occurred between the actuator hinge point and the ceiling connection of the turret.
So I modified the design and moved the hinge points to the center of the turret.
To match the length of the arc accordingly, the design was completed based on a new length of actuators available on the market and the steel plate was ordered to be cut and bent with laser beams.
Two actuators are designed and can be expanded to four if necessary.
If I extend it to four, I'll have the over power to control the up and down of the main gun.
Youngjae
