Sigh of relief on that one John
Following a special request from JC, time for an exhaust box update
All the main cuts to the basic box have now been made; time to start adding the detail and putting it all together!! I can just hear JC now......about bl**dy time
40 10BA bolts were added tp the top, front face and the air vent leaving 6 to follow later.....
The main parts were then assembled and the main fixing screws secured with Loctite Blue. Filler pieces were then added to the left and right of the front and also across the top. These were then filed flush and filler added to hide the screws...
After sanding down, the box was then etch primed. Once dry, the exhaust outlet ports were added; each port was secured with 3 M2 bolts. the other holes being filled previously. The gun clamp was then added followed by the air vent which slightly overhung the newly extended top. The air vent cover was then glued into place (knew I find another use for those spare tracks
and etch primed once dry.....
Time now to attack the comms box. The supplied item looks like this.....
- armortek box.jpg (50.77 KiB) Viewed 2589 times
The actual box looks like this.....
If you look closely, the box itself is almost square but not quite!! I'll be using the original picture to gauge sizes and as far as the width is concerned, the bolt positions! There is a lot of work to do so best get cracking!!! First, the box was thinned and shortened.....
The pretend mounting brackets were then cut off from the sides and the box widened to bring it more into proportion.....
The front of the box was cut and filed to shape from 1mm sheet. The hatch was made from L angle profile, cut and filed to shape......
The hatch and front were then glued into position and once dry, were filed flush with the main block. The sides of the block were then encase with 2mm sheet and filed such that it was just proud of the front face. Had I filed it flush, you wouldn't be able to see that it was infact a box. Various bolts were then added and brackets made from L angle profile and shaped appropriately were added. Stand offs were made from the floor material that was removed to do the angle plate mod and glued into position.
With it all etch primed, this is what it looks like in situ.....
- finished comms box.jpg (89.5 KiB) Viewed 2589 times
The bolts on the front are 10BA with M1.4 socket heads on the hatch. On the side, M4 and an M2.5 nut filed to half its height and drilled out to 3mm to accept the 3mm brass tube for the conduit. The brass tube will accept my home made braided wire.
There is light at the end of the tunnel for the exhaust box; not much to do now (fingers crossed
PS.......no JC, the hatch doesn't open
