Tiger Ausf E “F01” Gruppe Fehrmann
- AlastairCooke
- Has liked: 8 times
- Been liked: 649 times
Re: Tiger Ausf E “F01” Gruppe Fehrmann
Hi Simon,
Many thanks. There is plenty more to come: the engine, the turret, Zimmerit, recoil, smoke and flash, hatches, camouflage and markings plus weathering.
Alastair
Alastair
Alastair
- Has liked: 1907 times
- Been liked: 92 times
Lots and Lots of Great info in this Thread.
Later Tim
Later Tim
Tampa Bay, Fla area USA.
- AlastairCooke
Hi Tim,
Many thanks.
Hi All,
Update 19 Jun 24
Items epoxied to cover top... View from below showing use of countersunk fasteners... I will use Milliput to fill the hollows to level surface for the bonding tape.
Inner sheet bonded in place to give the characteristic milled edge and relief for the main vent weld...
Front vent:
3D printed part with deliberately rough weld detail added... View of underside, I included a filler piece in the large aperture to prevent any distortion during printing. Front vent in place...
Another test fit of hatch... Needs a little (0.5 to 1mm?) skimmed off the front.
(NOTE: all my 3D parts are created in Fusion360 and printed by Shapeways. If anyone is interested, they could be made available for sale. I cannot guarantee that they are all drop-in replacements on a standard Armortek Tiger 1 kit but that might be possible with some redesign.)
That's all for now.
Many thanks.
Hi All,
Update 19 Jun 24
Front vent:
That's all for now.
Alastair
- AlastairCooke
Hi All,
Update 4 Jul 24
Engine cover-internal details: building up the immersion locks from printed parts and pins: Cover catch: This is a Sixth Scale Icon part. Needs to be etch-primed and epoxied in place before the weld detail is applied.
Engine:
After a long hiatus, I have returned to detailing the engine with the inertia starter: and the generator: That's all for now...
Update 4 Jul 24
Engine:
Alastair
- AlastairCooke
Hi All,
Not an update but some news and a request for advice.
As you may know I have relied heavily on Shapeways for my out-sourced 3D prints in nylon, brass and fine detail resin. With the recent demise of this company I have been looking around for an alternative. Midlands 3D seem to fit the bill for nylon and possibly fine detail resin. They have no minimum order; are cheaper and, being UK based, have reduced shipping costs for me .
I am thinking of applying casting numbers to the domed cover on the rear engine cover and I am uncertain which number to choose. Whilst Tiger 712 (now 112 - Fgst.NR. 250031) has 33, Tiger 131 (Fgst.NR. 250122) has what looks like 77... any ideas or advice will be greatly appreciated.
Thanks,
![Smile :)](./images/smilies/icon_smile.gif)
Thanks,
Alastair
- Has liked: 746 times
- Been liked: 1730 times
Did not know that Shapeways is no more.
I sometimes go here for a commercial print:
https://craftcloud3d.com/
There are some UK based printers to be found there.
- Has liked: 111 times
- Been liked: 741 times
They filed for Bankruptcy this week. I used them a lot too!
- AlastairCooke
Hi All,
Update 23 Jul 24
Rear Mudguard Stays Stays finally installed. They have been in a bag for at least 12 months!
Rear sponson weld completed... As with the front, I have filled the groove that I milled into the rear plate at the beginning of the build.
Engine and Rear Covers
Getting there... Weld detail added and primed prior to fitting the locks. You can really see the difference between red oxide primer over Upol Acid 8 on the engine cover and just over raw black nylon on the rear cover. The difference will become more muted when the base coat is applied but will still be there to make the colour less monochrome.
I had some slight fit issues so decided not to fit the front immersion locks. The holes were modified by plunging with a 6mm end mill to leave something similar to that seen on Tiger 131. Remaining locks and stops installed. A close up of the locks... Immersion lock Hatch lock
Turret
I used a scissor jack to open up turret sides so that I could remove the front (CE1473). I then milled 0.25mm (10 thou) off each interlocking face so that it could slide easily left/right in the turret wrap (CE2470). That way I would know that the fit of the wrap to the base (CE2472) was only governed by the flex in the wrap. After priming the front, it was time to reassemble the turret...
First, the wrap was spread using my scissor jack and the front piece reinserted. I checked that it could slide within the wrap notches thereby ensuring it would not hinder the assembly. Next, the base was attached loosely using a M4 x 16mm cap screw at the rear. Then three M4 x 20mm cap screws tightly secured the front piece. This provides a guide for the wrap as the parts are pulled together. G-clamps were very useful in pulling the wrap against the turret base... One side complete using two more M4 x 16mm cap screws... Finally got it all back together... The screws were removed, one at a time, and reinserted with red Loctite applied.
Now I need to design a replacement roof, which will be a steel laminate like that on the hull.
Engine Block
Decided to put some paint on the engine block so that I could get the rear mount and flywheel installed. I am using Lifecolor RAL 7016 (Anthrazitgrau) over black primer. The paint seems to wear off sharp edges quite easily which is not necessarily a bad thing. Handling will produce some subtle weathering which I can lock in with a coat of matt varnish.
Update 23 Jul 24
Turret
Engine Block
Alastair
- AlastairCooke
Hi Tim,
Many thanks![Smile :)](./images/smilies/icon_smile.gif)
Many thanks
Alastair
- AlastairCooke
Hi All,
Update 14 Aug 24
Gun Elevation
After much consideration and many alternative designs produced in CAD I have decided to stick with the kit supplied mechanism. I will, however, swap out the motor for one with an encoder so that I can implement position control and dispense with limit switches etc. The main reason for this decision was concerns over how much of any other mechanism would be below turret floor. I want to ensure that there is no likelihood of contact with items in the hull. Equally, as I have no need for rapid response the lead screw system should be sufficiently capable. I may install some dampers to minimise ‘barrel bounce’. The idea, for now, will be to use a slider or rotary control on the transmitter to set the elevation.
Therefore, the first change is to my turret electrics/services plate. I need to open out the slot by another 40mm or so: The next is to design a motor mounting plate to enable use of a Pololu 37D 12V motor with the provided elevation bracket (CE2480). The width will be finalised when I have the replacement motor.
Lift Lugs
Pictures of the turret of Tiger 131 (published in the photograph album that came with the kit) show that all three lugs were of a similar design. Consequently, I decided to reduce the diameter of the rear pin from 12mm to 10mm to match the front ones.
Before... After... I will probably reduce the diameter of the head on the front ones down to 14mm to match the rear.
Later I decided to reduce the length of the pin by 2mm:
Replacement Roof
I test fitted the kit supplied roof to determine if the replacement needed to be a different size to fit my turret. As you can see there is about a 1mm overlap between the two roof pieces and so I shaved the same amount off my design. As the turret roof plate will be a laminate, I needed additional holes for some alignment pins. Images of F01 clearly show that the turret was delivered with smoke dispenser brackets and that these were later cut off before the Zimmerit was applied. I therefore arranged for a couple of the holes to be where the brackets would have been so that they can be hidden later. Roof design, note provision for weld seams and the cupola mounting which will be completed by a ring that will be 'welded' to the roof plate. A couple of the holes for the bolts for the loader’s periscope housing are not drilled through as they are very close to the fold line. This will be done later along with holes for the Milliput weld detail. I decided to split the upper plate at the fold line to allow laser cutting of more of the hole detail.
As I am approaching the five year point I though a montage showing progress to date would be of interest...
August 2019 August 2020 August 2021 August 2022 August 2023 December 2023 August 2024 That's all for now
Update 14 Aug 24
Gun Elevation
Lift Lugs
Replacement Roof
Alastair
- AlastairCooke
Hi All,
Update 4 Sep 24 (First of Year 6!)
I designed a replacement mounting fixture for the turret roof as I needed more support at the edges to avoid stressing the weld detail and a suitable location for some hold-down magnets. The new support is designed to use the existing fastener holes and be pinned together with some circumferential clearance to allow for measurement inaccuracies. Test fit of roof support, will be epoxied in place once turret interior has been painted. Replacement roof plate
The new roof plate is a laminate of two 1.5mm steel sheets. The lower one was folded to an angle of 8 degrees to match the turret wrap.
Lower sheet... Note that some larger diameter holes were cut or drilled to represent the bolt/nut clearance indentions in the actual roof plate.
Upper plates (temporality bolted in place)... Decided to add some supports at the front of the turret sides. They are made from some 1/2 inch square aluminium stock that was drilled and tapped for M4 bolts. The turret sides will be counterbored so that bolt heads ‘disappear’. Some imaginative work-holding was required! The weight of the turret helped to keep things in place whilst the pilot holes were drilled. Extra supports in place... Will probably design some front supports as well. As the fixing holes will have to be drilled from the front I plan to disguise them with a representation of the upper splash guard.
Engine display stand.
It has always been my ambition to display the engine outside of the tank. Consequently, I had some additional plates cut and folded at the same time as the roof. Test fit of engine stand... The stand has been designed to accommodate the inner part of the firewall as well. This will allow me to align the throttle linkage etc.
Alastair
