OPEN ON THE 6TH FEB 2025
David's carrier build.
Has liked: 2267 times
Been liked: 7152 times
Re: David's carrier build.
Lots done.
The 2.3ah will fit in there with a little modification
I will turn it upside down and cut slots for the terminals.
Lots of under coat which is also a top coat.
That's the bulk of the rivets done now.
Another two cans of paint used
Silver solder joints to help form a stable battery compartment
A morning spent on the electrics today, it's going to be tight as someone put a dirty great big V8 in there.
The electric motor and the engine is now bolted back in for I hope the last time.
Adjusting the battery box mounting holes
I didn't use this wiring route in the end.
I need to make a cover for that spinning drive shaft
It will fit, all the modules and the rx have Velcro mounts.
I need to make some nice brackets for the speaker and the switches.
Last edited by Phil Woollard on Mon Jul 25, 2022 7:33 pm, edited 2 times in total.
Been liked: 1644 times
very nicely done phil, Tight working conditions indeed, regards simon.
Lots done today .
These extra fixings need adding
Lots of little Armorpax parts.
The prop shaft needs some protection
Transmission tunnel in place
It's getting more organized in there, the rx and the sound card need to be conveniently placed so if necessary you can bind the rx and select the sound card program button.
Now into these lovely parts
Lots done in a sweltering workshop.
Most of this needs to go and be replaced with an even more compact system with even more goodies.
The motor fan and lighting harness.
So we have a master switch, and engine fan switch and a rear and front light switch.
The idea is that all the switches are directly accessible through the rear engine cover hatch, I need to get a charge socket in there too.
It's all in but not to tidy just yet and it all works
Oliver Brüninghaus
Has liked: 551 times
Been liked: 409 times
Post by Oliver Brüninghaus »
So many exciting and beautiful new details.
It's hard to keep up with so many interesting posts. :oops:
Thank you for all the great examples and inspiration. :!: :!:
Oliver
It's Grim Up North
Dave Green
Has liked: 87 times
Been liked: 62 times
Post by Dave Green »
Looking really good Phil. Loving the engine in there, its a cracking detail.
Gary Richardson
Has liked: 753 times
Been liked: 1772 times
Post by Gary Richardson »
What a great build, lovely detailing and the engine looks superb.
Gary
Lots done
Look at the state of my work bench
See if we can hang the engine cover access panels like the original
All the wiring is tucked in and cable tied with little room to spare
I've turned the hex head to form a round profile, that air cleaner looks better olive drab
Some of the Armorpax parts
I want to use the remote air cleaner piping if I can but I don't think there's enough room in there for the air cleaner.
Phil Dawe
Has liked: 755 times
Been liked: 298 times
Post by Phil Dawe »
Great build thread Phil. I am sure Dave will be delighted when its finished 8)
Dave Green
Has liked: 87 times
Big smiles all the way through. Looking forward to the finished vehicle but enjoying watching things come together.
I'm back on the case.
There a lot of Armorpax detail to go in here
Slicing up the seat frames
Most of this lot is still to fit
Nice seat pads.
Nice seat pads.
Just about sunny enough for painting
Our 12" figures don't fit these vehicles
The battery box is made from 2mm sheet stock, I may replace with plasticard , the Armorpax batteries are to big or the box is to small.
Dave how would you like the radio fitted, it's to wide right now as the engine cover extension piece is now in the way? I see Mr Dibb sliced his down so one third is mounted on top, maybe this is the way it should be, the join is only one wall thickness so I'm doubtful, all I need to do is add a card end to one piece.
Oliver Brüninghaus
Hello Phil,
The level of detail here increases in inverse proportion to the size of the tank.
Very beautiful!
It's Grim Up North
Thanks Oliver , I'm loving this little/ big kit.
Brutal but necessary
I had every intention of fitting some of the drivers controls but that radio needed some work
The mill used to square the body, it's so quick this way
Card used to cover all the milled sides, and also used for the mounts
I've said it before, watch this type of cyno the capillary action is awesome, down your finger too!
My good ol cutter
My good ol cutter
It's going to live just here.
Dave Green
Has liked: 87 times
Looks great and fits like a glove!
