NOW OPEN
CLICK HERE FOR MORE DETAILS
Has liked: 2267 times
Been liked: 7152 times
Getting on with the zimmerit. I shall install the side skirts today, finish the front zim then start planning the engine bay fabrication.
Just the remaining front plates to do and the hull is ready for an engine bay.
Near side running gear all painted in DG inside and out.<br />Sprockets keyed and lined up, road wheels have their fixings, if I'm careful the road wheels can now stay on as I should be able to add the weathering colours in and around them.
Reduced head bolts for idlers, I'm getting low on stock of these, I do recommend the serious builder to keep a supply handy
mark j. radick
Has liked: 393 times
Been liked: 538 times
Post by mark j. radick »
Looking awesome ! I am so amazed at your progress !
BobGrey
Has liked: 115 times
Been liked: 2 times
Post by BobGrey »
Hi Phil loving your build as usual. Apologies if it has been mentioned before but what tile cement are you using for the zimmerit? I think it is time to try it instead of milliput!
Bob & Graeme
florian rudolf
Has liked: 294 times
Been liked: 641 times
Post by florian rudolf »
Hi Phil,
verry nice build indeed.
The customer must be verry happy about it.
Thanks Florian I hope he's happy with it! wait till you see todays progress tomorrow, the sub units are now coming together nicely. I've not really even started on the turret as yet. I'm getting through paint like crazy, I am keeping all the used cans and will post a photo of them ( landscape ) at the end.
Hi Bob, thanks for the kind words, the tile cements trade name escapes me but it's just a ready mix of half a kilo, it sticks like sh.t to a blanket! It's not easy to use by its very nature but you have about an hour maybe two before it starts to harden so you can easily "lay up " an entire plate and work away without to much pressure. Just remember my wd40 tip. 8)
While I think about it, are there any high detail Tiger 1 track links for sale? We need some nice examples to hang on the T1.
Hard to see but the slots behind the reduced head size fender bolts cut as the original, don't ask me why they are there.
The red oxide applied for later weathering.
I have made new brackets for the fenders, which are now bent.
A small amount of operational damage.
I needed to try my new spraying equipment so some shading would prove the kit, and I'm very happy with it.
A bit of pre shading
A bit of pre shading .
Just the horizontal plate to go.
A little operational damage to the fenders.
Has liked: 777 times
Been liked: 1745 times
Great progress Phil. Wish you were doing the turret.
Cheers Vince, well it won't be long until I start on the roundy bit 8)
Phil Dawe
Has liked: 755 times
Been liked: 298 times
Post by Phil Dawe »
Loving it all! :lol:
Zimmerit all done, I have made a start on the engine bay, firstly I must put the various units together as the dimensions of these determine the width of the fire walls, the thickness of the material that I shall make the engine bay floor from... everything really.
The tile cement container is there in shot and it's "Evo-stik"
One of the radiators having the flashing removed, it turns out that it will need a whole lot more that that removed.
One of the radiator castings is as pissed as a hand cart, so I need to establish a datum to work from.
Using my stuck down sanding dics to get the casting flat.
Big &quot;init&quot;
Big "init"
The first of the fan drives is taking shape, I can now take some measurements.
All the zimmerit done for the hull.
The new air brush set up
How can they do it so cheaply, maybe it wont last!
Last edited by Phil Woollard on Thu Aug 01, 2019 8:23 am, edited 2 times in total.
Ivano Costantini
Been liked: 735 times
Post by Ivano Costantini »
These don't need all that work!
tigre mid 1-6 112.jpg (18.71 KiB) Viewed 1703 times
tigre mid 1-6 113.jpg (14.56 KiB) Viewed 1703 times
tigre mid 1-6 114.jpg (18.56 KiB) Viewed 1703 times
tigre mid 1-6 115.jpg (20.65 KiB) Viewed 1703 times
Hi Ivano, they look nice. With a lot of fettling maybe ours will look as good? 8) Are you offering these for sale and if so what's the price?
As we are talking about cars....I'm off to a big car show at Mount edgecombe here in Cornwall this Sunday so if any of you guys wants a different day out I will be in the super car line up with my Armortek cap on! Come say hello, and if you have an Armortek model at home then a coffee is yours!
John Heath
Has liked: 4 times
Been liked: 102 times
Post by John Heath »
Love the way it’s coming along. You’re not hanging about are you? 😁
These little compressera are good aren’t they. 👍🏻
John
I used the same tile adhesive for the zim. As a first-timer I found it quite good and forgiving. When I removed my first attempt I had to use a wood chisel and hammer!
P.s. How do I get an Armortek cap?
Last edited by Vince Cutajar on Thu Aug 01, 2019 11:45 am, edited 1 time in total.
Ivano Costantini
Thank you very much for the invitation, but I'm a little too far for a hahahahaha coffee, Italy. For the price contact me in private, I never advertised my articles on the forum.
