Panther Progress!
Hi Bob
Nice computer work. Why not just put two flats on the black/Delrin part for a simple finger hold?
I guess I have been lucky. I'm able to get mine off using only fingers.
best regards
Has liked: 158 times
Been liked: 830 times
Hi Tim,
Yes there are many options, another is to flute the delrin piece lenght wise in between the holes to make it like a screw driver handle and forget the holder piece. I just happened to have the piece of alum that happened to fit the piece of plastic I had so I went with it. The Delrin pieces I had were too small to use without some kind of holder, they are only 1" long - easy to STILL knock your knuckles on those rim bolts.
I installed the hub caps finger tight but when I weathered them with the paint wash to simulate grease and grime I think that "glued" them in place. Some were really stuck and took a lot of reefin even with the tool.
Chang
Has liked: 16516 times
Been liked: 487 times
Post by Chang »
Hi all,
I have the same problem---not on Panther but on Kingtiger. Courtesy Derrik's suggestion, I find the possible solution here for my KT. Thank you all for the info. :idea:
Lerh Chang
Hello Lehr,
Yes I think if you use pins instead of the holes in a similar tool per Dereks suggestion it should help the hub cap to break free. I never realized paint could be such a good glue.
Let us know how it works out for you - and best of luck!
Took an idea from Dale and made some mesh screens for my Panther. Thanks Dale for the idea and inspiration. The ring is easily machined. Glueing the mesh in with epoxy is so much easier than trying to solder it! Anyway they came out nice. You can mount them machined side up or glued side up if you prefer the rougher texture (to simulate welding). I will add a PDF drawing to my gallery.
File path to the PDF:
Gallery-->Bob Morey--> Drawings and PDF's-->Grill screen with mesh
-->click on photo-->then "download document" to open drawing.
Machined side up:
Or Glued side up:
Hi everyone, I have added a simplified hub cap tool drawing to my gallery. It is in a folder called Drawings and PDF's.
Jeff Hyder
Been liked: 3 times
Panther Progress
Post by Jeff Hyder »
Hi Bob,
Thanks for the info and photos on how you did your grills.The main problem I was having on my KT was with the mesh covering the grills are made of steel and does not manipulate or solder very easily.All ok now apart from trying to get my fingers unstuck from the super glue!I still have not made the large grills that covers both square grills under the turret.With the experience of the smaller grills I have high hopes these should turn out ok.
Thanks again Jeff Hyder.
Dale jordan
Been liked: 483 times
Dale grills
Post by Dale jordan »
Hi Jeff .. Where are you up to with your KT build ??.. With the grills did you see my post on how it did my grills ... It's not that bad ... If you need any help just pm me ...Regards Dale
Phil Markham
Been liked: 22 times
Post by Phil Markham »
Hi Bob,
PM sent.
Nick Farrugia
panther build
Post by Nick Farrugia »
Hello Bob
i have just discovered your build pics of your panther very profesional it looks to.I have just spent the best part of two hours going through your posts very impresive ,not only are you very talented craftsman but you have great taste in music too 8) :D .
Enjoyed all your posts sorry i was late getting here.
best wishes
nick
realy like the battle damage ,i think it takes a bit of courage to knock scrape and dent these models after all the effort
that go,s into building them ,but you have done a great job .
nick
Hi Nick,
Thanks for the kind remarks. The forum is great because no matter how old the build photos are they can still be a treasure when you find something interesting.
I admire your skills to design and build a complete model of your own. that takes some supreme dedication.
I look forward to seeing more of your work in the future!
Paul Morris
Been liked: 68 times
Post by Paul Morris »
Hi fellas.
I did the same thing regarding the Panther hub caps although mine is not delrin as I had none to hand so mine is aluminium with a slot milled in the rear so you can use a screwdriver to fit and remove them, I also added a few drops of light oil to the threads to help them along,you can see this in part 2 of the Panther blog.
I have also seen this this same thing happen on the Tiger 1 on a few models including my first one, the addition of a simple lock washer on the cap head stops it altogether.
Cheers Paul :wink:
01524 720977
