T34/85 25th Guards Brigade No 234a
John Fitzsimons
Has liked: 6 times
Been liked: 822 times
Re: T34/85 25th Guards Brigade No 234a
Post by John Fitzsimons »
Exactly what I was told. Use whatevrr they had to hand to fill and grt them off the asdembly line quickly.
phil fitzpatrick
Been liked: 223 times
Turret
Post by phil fitzpatrick »
Put some Primer and Green On my Turret,Still have the Cupola casting to do and a bit more
to the Turret Vents.
Sorry about the picture quallity the sun was low and bright whenI got home.
Derek Attree
Has liked: 219 times
Been liked: 200 times
Post by Derek Attree »
Hi Phil
Is that the same shade of green as on your comet?
looking good :)
phil fitzpatrick
Hi Derek
Its Not too far off.
For my Comet I mixed 3 colours
Equal parts of Lifecolour UA506 olive green and UA221 Khaki Olive Drab and a bit of
burnt umber UA037.
You couldnt tell the difference from each mix I made up.
The Green I am using at the moment is a Green I came across Vauxhall Leaf Green and I have been
using it to spray the big areas in the garage as a base coat after priming for the air brushing I will be doing
soon,now I have moved it inside,into my spare room,so yes its not far off the Comet colour.
I sprayed it in thin coats and at a longer distance than normal so its a mixture of semi gloss and mat finish.
For my Air Brushing I am using Lifecolour UA002 Green Verde and UA237 Dark Olive,Both from the FS34102 Range.
Then I will do some fine air brushing and dry brushing after,the part I had fun with.
phil fitzpatrick
Cupola Casting
Cupola Casting
phil fitzpatrick
Turret Top Detail
Some more work on my Turret Top
Fitted Cupola,bit more Casting Texture on my Air Vents,Hatch Latches and Antenna.
phil fitzpatrick
Side Mudguards
Side Mudguards
John Fitzsimons
Has liked: 6 times
Very nice work.
Has liked: 162 times
Been liked: 849 times
Phil,
The cast effect on the turret looks even better painted! Wow! Overall looking very good! The details are really making your model stand out. Thanks for posting progress,
phil fitzpatrick
Thanks John and Bob :D
Took my wheels back off and done some air brushing of my lower hull this week
phil fitzpatrick
Bit more detail on my front glacis plate
phil fitzpatrick
Rear Mudguard
Rear Mudguards fitted
Has liked: 1040 times
Phil - I've been admiring your work in silence too long. Great stuff. Must be difficult to keep thinking Russian, agricultural, less than perfect if you've got high standards - perfection not required on this one!
Don't know if you've seen my post elsewhere on the Adam Wilder DVD on Photoetch techniques but it might interest you. The DVD is based around building a 1/35th T34/85 with Thoma screens. He includes a stack of close ups of a real tank in Moscow and I'm sure if you freeze frame and do a screen dump, you could use it.
On my Pz III, I got hold of a 1/35th photoetch pattern for the Rommelkiste and scaled it up to make in brass. There are alot of photoetch kits for the T34 from companies like Aber. Might be something to think about if you're thinking of adding detail.
Looking good and thanks for sharing.
phil fitzpatrick
Thanks Stephen :D
I was doing a bit of air brushing on my wheels last night,Too much of a rush after work,Too poor
lighting,too much thinners and not mixed enough.
Those mistakes ended up starting to look like the photo of a dusty wheel with some white marks
that Brown had posted early on,when I went back to have another quick look:)
So I am finding I can make use of some of my little mistakes.
Yes thanks for that posting on the photoetch,My disc is already on its way,I like to learn about
all the new skills that are new to me and pick up any other detail bits on the way.
phil fitzpatrick
Tracks Fitted
Some Pic's of my Tracks fitted
