A34 COMET
phil fitzpatrick
Been liked: 223 times
Cupola door latches
Post by phil fitzpatrick »
phil fitzpatrick
Aerials and details
phil fitzpatrick
Head pads for hatches and inside latch
Leather Head Pads and straps for Loaders hatch and Cupola doors.
Inside Latches for cupola doors
phil fitzpatrick
Head pads for hatches and inside cupola latch
Leather head pads and cupola inside latches
phil fitzpatrick
Search Light
Once there was a beautifully crafted Armorpax Search Light with a Dust
bin lid for the front.
But now I think Ive done Dave's fine work justice :D
Search light off
Search light on (took on the night and the flash went off)
Search light head on
Search light on pivoted to side
Search light back off
Search light on Looking up
phil fitzpatrick
Search light conduit
phil fitzpatrick
Side Hatch latched open
robert michael hilton
Put that light out....don't you know there's a war on.....only joking....showing my age now. :lol:
Very inspirational Phil.....brings the Comet to life.....mick
phil fitzpatrick
Normandy Cowels and Mesh
Normandy Cowels and Mesh fitted
Hello Phil, I am assuming that the parts fitted to the sides of your pannier, which look like they hold the pannier lid open, or stop the lid opening too far, are not in the kit.
The part looks like a tube with a wire which runs from the side to the lid. Is this hand made?. John has the same system. If so, I can make my own later in the build....thanks...mick
phil fitzpatrick
Panier Stay
Hi mick
Yes the Panier cable stay was self made and the bits inside are just thin
galvanised sheet scrap from work.
I still used the magnets,both on the front edge after hingeing the lid,it was
trial and error for the position because they are very strong.
Chears
Nick Farrugia
comet 1A
Post by Nick Farrugia »
Hi phil
great job on the search light looks realy good ,as does all the other bits you have added .looking forword to seeing the tracks going on . Great build of a very impressive model .
best wishes nick
phil fitzpatrick
Comet
Hi
Thanks Nick
Once I found out that I could drill wide enough for the Led cables it was
just a matter of the reflector and led.
The reflector was easy,good old B&Q had a modern little torch with a
plane reflector at the exact diameter I needed.
I have started the tracks,I have assembled the one run of 111 links,doing
20 links per can of Magniers Cider sitting out in the sun, but I left that to
carry on with some of the other build untill I get my option packs.
I am going to copy some of your tools you did,but I dont think I will be
able to do that little Pipe wrench,it was amasing.
Thanks for your answer Phil. I will leave all or most of any extra add-ons until I have built my Comet kit.
Can't wait to have it running....I suppose there is nothing stopping me fitting the motors......no no no.....be patient.
The more parts you fit the more 'tank like' it becomes. I have interchanged some of the bolts and I did move the cable bracket...thanks again....mick
phil fitzpatrick
Tracks
Tracks fitted
