New member panther g 1944
Ed Groenenberg
Has liked: 96 times
Been liked: 632 times
Re: New member panther g 1944
Post by Ed Groenenberg »
Gary Rafferty wrote:
Sun Apr 02, 2023 3:06 pm
Hi All,
Change of plan today.
Watch all the panther builds, and very impressed with the progress.
I've dry built the turret as a few members mentioned they had issues with fitting.
On mine the 2 curves on the base are to tight stopping the side panels pulling in tight all the way along.
And on the mantelet fitment it appears to be slightly offset on the right is this correct?
Gary
Hello Gary.
Yes, I used an electric sander to change the curve a little on the 2 aforementioned spots.
I did try Brain Ostlind's method too before changing the corners, but that somehow did not make a significant change in the gaps.
The mantled has indeed a little offset on my model too. It appears to be correct, but it looks a little 'odd' from an aesthetic/symmetrical point of view.
See the (excerpt) below. Picture was made by Rini Koks of the Samur Panther.
Gary Rafferty
Has liked: 252 times
Been liked: 442 times
Post by Gary Rafferty »
Ed Groenenberg wrote:
Sun Apr 02, 2023 9:00 pm
Hi All,
Gary
Hello Gary.
The mantled has indeed a little offset on my model too. It appears to be ok, but it looks a little 'odd' from an aesthetic/symmetrical point of view.
Hi Ed
The corrections were Thankfully an easy fix, I will fill/weld bead the small gaps left
Thanks for confirming the offset on the mantlet.
You're build is looking superb, very fast progress.
Gary
Jae-seung Roe
Has liked: 278 times
Been liked: 129 times
Post by Jae-seung Roe »
Sun Apr 02, 2023 5:29 pm
Hi All
Sorry for all the posts..
While the grinder was out thought try the cut marks for the steel plates.
Not sure it's quite correct.
Gary
nice work of adding detail of torch cutting! looks great! :D
Gary Rafferty
Hi All
Seeing as been working on the turret might as well cary on..
So dry fitted spare wheels and track links.
Bit of pain with all the shapes of the turret.
Gary
Gary Rafferty
Helps if attach the picture..
Riny Koks
Has liked: 1010 times
Been liked: 97 times
Post by Riny Koks »
Hi Gary,
I like the spare wheel on the turret, however i would either change the buttonheads for hex heads or put the buttonheads on the back and the nuts on the front.
Last thing is the real thing.
Keep it up,
Riny Koks
Panther wheel
Panther wheel
2019 M3 Lee #25
2022 Panther G #6
2014 Sd Kfz 7 #6
Pak 43, Flak 36
Bailey Bridge + Extension
Gary Rafferty
Riny Koks wrote:
Mon Apr 03, 2023 6:34 pm
Hi Gary,
Keep it up,
Riny Koks
Hi Riny
Many thanks for the support, I realised when I had them machined down that they didn't look right hadn't got around to changing them.
Another job to add to the list.
Watching your build looking really good.
Gary
Stephan Joubert
Has liked: 38 times
Been liked: 49 times
Post by Stephan Joubert »
Hi All
Gary
Those "flame cut" marks look great. Another small detail to add to myne. Keep up the good work!
Stephan Joubert
Has liked: 38 times
Mon Apr 03, 2023 5:33 pm
Great idea, look at this 1/16 wheel for some added detail:
Gary Rafferty
Stephan Joubert wrote:
Tue Apr 04, 2023 5:31 am
Hi Stephan
To be honest I'm not going to build this detail into the wheels.
The nuts and bolts are oversize compared to the real ones.
This picture is the other way round but gives you an idea on size.
I think by adding the steel nut retainers will make it look even more oversize.
I don't think anyone with the latest release has added this detail, however I could be wrong.
Gary
Riny Koks
Post by Riny Koks »
My wheels should look like this
Riny
Smaller nuts on the standard buttonhead which is on the backside and not visible.
2019 M3 Lee #25
2022 Panther G #6
2014 Sd Kfz 7 #6
Pak 43, Flak 36
Gary Rafferty
Riny Koks wrote:
Tue Apr 04, 2023 11:01 am
Riny
Hi Riny
They look superb, however I would be concerned that the nuts are not really getting much bite as they are not much bigger than the bolt holes.
Gary
Stephan Joubert
Has liked: 38 times
Sun Mar 26, 2023 1:10 pm
Hi All
One bin done one to go..
Hi Gary, are those latches on the bins part of the standard kit?
Gary Rafferty
Wed Apr 05, 2023 1:25 am
Hi All
Hi Stephan
I have a ton of after market parts going on the panther when I get that far.
those hinges are from Armorpax.
Gary
Gary Rafferty
Hi All
Wheels and tracks dry fitted happy with the results, turret corrected.
Will dry fit mantlet,barrel just to be sure then get some primer/and dunkelgelb on it.
Gary
