Mr Dawe's Centurion.
Has liked: 2259 times
Been liked: 7149 times
Re: Mr Dawe's Centurion.
Lots done, now moving on to the final drive outer pieces.
Drilling the centers for the covers
Turning a mandrel for the cover centers.
Its so easy with dro and a rotary table.
Checking its all in the right place.
The arse is nearly done
Getting on with the outer final drives. The basic milling is done for the first side.
There's a long way to go yet.
The other side now, well working on both at times.
Thought I better put these up as it was 40 years ago it all kicked off down there!
The castlated filler caps.
Has liked: 1023 times
Been liked: 2093 times
Ah, MPA - aka Mount Unpleasant.
For reference.
Milling, turning, drilling, cutting, filling and tapping and some tea drinking.
A big lump of 40mm stock.
My least favorite job, parting off.
More of those lovely m3 reduced heads Mr D!
The hole circle function is great.
Phil Dawe
Has liked: 754 times
Been liked: 276 times
Post by Phil Dawe »
Loving it all Phil! Those round inspection plates look the part! You deserve another cuppa!
These final drives have so much detailing required but I think it's very worth it.
Flat bottom drill bit, very useful
Domes
Domes
12ba bolt detail
12ba bolt detail
Oliver Brüninghaus
Has liked: 551 times
Been liked: 409 times
Post by Oliver Brüninghaus »
High-speed modelling in perfection.
Very inspiring :!:
It's Grim Up North
Thanks Oliver, lots done today.
Casting id, lots of casting id.
Weld detail at the rear as I had milliput left over from the final drives
Texturing done for now.
The final drive fillet piece is often overlooked.
Good ol filing.
Good ol filing.
The best way to transfer a shape?
Mirroring is easy
Mirroring is easy
I tend not to use a jigsaw.
I'm happy with the fillet piece.
Last edited by Phil Woollard on Sat Apr 09, 2022 6:09 pm, edited 3 times in total.
Phil Dawe
Post by Phil Dawe »
Phil,
I am extremely impressed by your attention to detail. Keep up the good work!
Has liked: 122 times
Been liked: 753 times
Lovely makeover on those drive cases! You and your team of elves are first rate!
Almost finished the running gear
It's all in bits again but not for long.
The only gasket you will ever need with an Armortek assembly........grease.
A little job I've been putting off, the four holes in the return rollers.
I can now get off my knees!
Setting up, very import that.
If you are careful some lateral adjustment can be made here.
Using my tube technique to get the sprocket perfectly in line.
This needs to be tight!
Grub screws.
Grub screws.
Suspended
Suspended
I want to use the kit part just modified.
The louvres. I take my hat off to you Stephen the standard of work that you achieved with your Cent was amazing.
I didn't think I would see this area again but it makes fitting out this part a whole lot quicker.
Best make a few test pieces first me thinks.
