OPEN ON THE 6TH FEB 2025
Early or mid ? Tiger 1 build by Phil Woollard
Chang
Has liked: 16035 times
Been liked: 452 times
Re: Early or mid ? Tiger 1 build by Phil Woollard
Post by Chang »
Phil Woollard wrote:
Sat Nov 28, 2020 5:23 pm
Detailing the turret vent, as it has the cover you really need to add the wing nut detail.
Hi Phil,
What is the size of these wingnuts ? 2.5mm or smaller ?
With regards,
Lerh Chang
Has liked: 2267 times
Been liked: 7152 times
M2 Chang. 8) Regards Phil.
Chang
Post by Chang »
Hi Phil, PM sent.
Lerh Chang :)
The mine dischargers and the track link hangers. 8) The steel tracks are now being held at the Brisbane airport,(and have been there for two weeks) awaiting a freight flight to become available to the UK.
Far to clean but I have to start somewhere.
These track hangers are white metal but a very tough version of!
I shall add some casting numbers to a few of the hangers.
Mike Kasputis
Been liked: 54 times
Post by Mike Kasputis »
Love all the detail going into this build, some excellent work. But your lower track brackets are in the wrong location.
Here is where they should be.
John Heath
Has liked: 4 times
Been liked: 102 times
Post by John Heath »
Useful drawing.
Good point guys, now do I keep the hangers or remove them as 503 didn't use them anyway at this time, if I want to be accurate with portraying vehicle 331 they should go? 8)
On another subject, the commanders hatch. There's often debate over the colours used for the internal face of the hatches, is a tactical camouflage colour correct or use the ivory internal colour? If you study the photo of 331 with its commanders hatch open it obviously has been painted using the interior shade, and with the head piece being so dark it sure presents a "bulls eye" target! 8)
I really think that they should go!
John Heath
Has liked: 4 times
I’ve been looking into the colour used for the inside of the hatches and it is a frustrating subject as I can’t find anything definitive.
An early Tiger would have had the inside of the hatch painted the same as the rest of the interior but was often repainted by the crew particularly when applying the camo. However this wasn’t always the case and some left the inside of the hatch the original colour.There just aren’t any hard and fast rules for this.
The only way to know for sure would be to find a good photo of the tank in question that might give a hint as to the colour but that is highly unlikely isn’t it.
I’m going to be going with the crew repainted the inside of the hatches on my early Tiger as it just seems like something that that the crew would do.
Almost finished the turret, just the cannon to go really. 8)
The locking bar fabrication.
Making the escape hatch turn screws.
Vince, even the tiny terminal block screws printed perfectly on the regulator box.
I've added a wing nut to hold the locking bar as it's more convenient.
The track hangers removed, there will be 331 there instead.
Has liked: 775 times
Been liked: 1740 times
Did you figure out why I sent you an stl file of a loose nut?
For the round profile electric junction box terminals?
You win a beer for the correct answer.
Lots done today 8)
This is sketchy!
This is sketchy!
Very nice machining on the muzzel break.
M22 takes some pulling round by hand.
Made the threaded tube that couples the blank firing device to the barrel.
Turrets all painted.
Butt crack!
Butt crack!
Unit markings and the rear deck grills today. 8)
Ooo don't know how these got on here!
A little project I'm working on, well I'm making two of these 115 10 ton trailers. I just need to check with the boss if it's ok to post a thread, I will be using Armortek wheels, tyres, spring sets and axles.
on to the grills. If you don't roll the edges they won't look real.
Rolling the edges of the etch sheet.
Using my bending machine where I can.
How you fix these is basically up to you.
Michael Röder
Has liked: 77 times
Been liked: 113 times
Post by Michael Röder »
Hi Phil!
Sd.Ah.115 is a very great project.
Please start a build thread!
