Hi all,
I recently experienced a not so fun thing while driving the Panther down in California. Which incidently, is over 900 miles from my workbench!
Several of the M4 screws holding the road wheels worked loose. The first indication something was very wrong was when the road wheels began to wobble significantly. I thought I had bent an axle or broken a torsion bar!
Both of which would be REALLY bad....shortly thereafter two road wheels just fell off and upon closer inspection another two were waiting to fall off!
Trying to reinstall the wheels led to the next issue. The little hub caps were stuck in the wheels something fierce. Trying to remove them "in the field" resulted in scratched paint, dinged up hub caps, busted knuckles, %^&$@@% swear words and other anomolies.
We got the wheels fixed after a fashion, but when I got home I made the following simple tool to help easily remove those little bugger
hub caps when they are stuck on tight. It also helps prevent cross threading when putting them back on. I suggest all Panther/Jagdpanther owners make something similar to this tool and put it in your field tool box. Its a simple project with basic machine tools.
You don't really need the holder body but it helps get a little more grip on the tool. The tool itself is made of delrin plastic to prevent damaging the hubcaps or the paint on them. The holder can be alum or PVC. The tool part is also intended to be reverseable -when one side gets bunged up, flip it around and use the other side.
The PDF drawing for my version is located in my Armortek gallery as follows:
Gallery-->Bob Morey-->Panther-->page 12, last item will say "no thumbnail"--> click "no thumbnail", then click "download document". This should open the PDF drawing. It is two pages. Save it or print it out.
Hope you find this useful. Have fun, happy tankin and keep all the wheels on...
