Page 11 of 21
Re: A 47 years old love
Posted: Fri Mar 27, 2020 10:26 am
by Fabrice Le Roux
Very tidy!
What printer and print setting do you use for small parts?
cheers
Fabrice
Posted: Fri Mar 27, 2020 5:29 pm
by Frank Breitenbach
Hello Stephen and Fabrice
Many thanks for your kind words.
To your questions Fabrice:
The 3d printer is a Zortrax M200. I have following main adjustment options: Layer thickness from 0,09mm to 0,19mm and to print only the surface with a support inside between 40% and 100% (a complete 100 % full print). The minimum part thickness is 0,8mm. The main problem is to place the part that I have the best result. It is a question of experience - I will say, many fails.
I hope I had find the right words.
All the best
Frank
Posted: Fri Mar 27, 2020 6:32 pm
by Fabrice Le Roux
Frank,
what nozzle size and filament do you find best?
cheers Fabrice
Posted: Sun Mar 29, 2020 1:39 pm
Hi Fabrice
The diameter is 0,4mm nozzle/ 1,75mm for the filament. There is no option.
I use normaly the ABS Filament. For me it is a good balance between Price and shrinkage.
Frank
Posted: Wed Apr 01, 2020 12:42 pm
Hello at all
The hull is now complete. The last part was the head lamp. I saw it at the Bovington Centurion. I have only one photo. So I hope it is ok.
All the best
Frank
Posted: Wed Apr 01, 2020 1:01 pm
by Fabrice Le Roux
Frank,
Outstanding! Just the right colour light.
Fabrice
Posted: Thu Apr 02, 2020 9:58 am
Hello Fabrice
In fact it is very easy.
The parts I bought more than 20 years. The 8V lamp gets 12V. The lamp mirror with a little modification and the lens gets a 3D cover.
Frank
Posted: Thu Apr 02, 2020 8:41 pm
by Christoffer Ahlfors
You do mean the opposite, don't you?
Posted: Sat Apr 04, 2020 3:36 pm
Hi Christoffer
No, no. The 8V lamp used with a 3s lipo (exact 11,1 V). So the light is a little better.
Frank
Posted: Mon May 04, 2020 10:29 pm
It will burn out in no time.
10% overvoltage cuts the life in half.
Posted: Thu Oct 01, 2020 9:30 am
Hello at all
After a long time now I can go back zu my hobby.
Actually I build the turret bins.
Frank
Posted: Thu Oct 15, 2020 7:49 am
Hello at all
Some new Details.
Frank
Posted: Thu Oct 15, 2020 1:06 pm
by simon_manning
Very nice, a lot of work goes into the small details, Excellent, regards simon manning.
Posted: Fri Oct 16, 2020 4:43 pm
Hello Simon, thank you.
That is right, but more details makes our models more interest and it makes fun.
Frank
Posted: Fri Oct 16, 2020 5:23 pm
by Robert E Morey
Frank,
Excellent looking bins and hardware. Looks like you milled the strap buckles? What size is the cutter bit that you used? Nice work!
B
