Model recovery - how to do it?
Gerhard Michel
Has liked: 3 times
Been liked: 687 times
Re: Model recovery - how to do it?
Post by Gerhard Michel »
Peter Quambusch wrote:
Thu May 04, 2023 2:20 pm
As you say "a tank is a tank" why don't you use one to recover the other? Did that several times with mine.... KT is strong enough to pull a JP over more than 500 Yards out of a sand pit, or a Sturmtiger out of the woods.... both with tracks on.... Just pulling a KT out of these environments with tracks on is a no go...
Peter
Hi Peter,
of course this is a possibility. But I prefer to avoid empty batteries, and this was the main cause for failures I saw till now (the other were broken track links). Moreover non-Armortek models might have no suitable mounting points for real towing. I afterwards fitted all my models with durable mounting points to fix them in my car. These points can also be used for towing, but till now I didn't have the necessity to tow another model.
Gerhard
Jerry Carducci
Has liked: 3 times
Been liked: 1119 times
Post by Jerry Carducci »
Gerhard Michel wrote:
Thu May 04, 2023 10:37 pm
...... Moreover non-Armortek models might have no suitable mounting points for real towing. I afterwards fitted all my models with durable mounting points to fix them in my car. These points can also be used for towing, but till now I didn't have the necessity to tow another model.
Gerhard could you elaborate on this a bit and show an example? Thanks.
Peter Quambusch
Been liked: 1045 times
Post by Peter Quambusch »
[/quote]
Hi Peter,
[/quote]
Hi Gerald, The JP's electronics failed in the banking heat of Eckermühlen sandpit and the Sturmtiger lost an idler wheel during test runns. But so far never any empty battery.... But the cause is of no interest. If the tank doesn't run, you have to recover it, or blow it up... :D
Peter
