Jagdtiger number of track pairs and track tension
Brian Ostlind
Has liked: 975 times
Been liked: 2068 times
Re: Jagdtiger number of track pairs and track tension
Post by Brian Ostlind »
I wonder if they will have those parts for replacement I would guess not. Like Dale said you might be able to save it. I hate making catastrophic mistakes so I know how you feel. The best way to avoid that situation is to make sure you don’t force any parts and ease things together with filing and fettling as you fit. Good luck!
Chang
Has liked: 16559 times
Been liked: 487 times
Re: Damage of the gun Elevation Pivot and Gun Sleeve
Post by Chang »
Dale jordan wrote:
Tue May 02, 2023 11:17 am
Hi Chang is it a grub screw ? try heating it up and re cut the slot with a hacksaw It should come out if not a grub screw it can be re taped and new pivot made Dale
Hi Dale. The Elevation Pivot (CT0411) is not a grub screw. Heating up and slot-cutting were both tried but failed. Its thread
are already damaged, and of the Gun Sleeve (CT0404) possible too. Until CT0411 can being taken out, no re-taped could be think of.
Brian Ostlind wrote:
Tue May 02, 2023 2:40 pm
Hi Brian. Like I have mentioned, the original assembly was so straight away and easy without any problem. I should not have taken them apart and tried adding a washer. Once it was stuck there, all hell are loose. All my attempts were ended worse. I still don't understand why did it happened and why is it so difficult to be removed?
Anyway, thanks for your advices. I will try again. Meanwhile, re-order parts is the higher priority.
Chang
Post by Chang »
Good news today :
(1) I have finally unlocked the Elevation Pivot (CT0411) from the Slew Pedastall (CT0405) and Gun Sleeve (CT0405).
(2) The Elevation Pivot (CT0411) is only with small damage on the head , not the thread part.
(3) No other damage on both CT0404 & CT0405 found.
1-6 JT-118.JPG (87.75 KiB) Viewed 4273 times
Still need re-order the CT0411.
Brian Ostlind
That’s great news!
Dale jordan
Been liked: 514 times
Post by Dale jordan »
Well done Chang . How did you do it ? Dale
Chang
Post by Chang »
Dale jordan wrote:
Wed May 03, 2023 11:35 pm
Before yesterday, I have tried deeper-cutting the top slot, spraying WD40, heating-up by hair gun, un-screwed by universal quick grip N snap wrench. All were failed, and that's why the CT0411 head looks so bad, and I guessed the threads of both CT0404 and CT0411 must have totally destroyed. :(
Yesterday I just tried using the universal quick grip N snap wrench again as the last resort. Suddenly it moved, and was finally out. I was glad that the threads of CT0404 and CT0411 are still good. :mrgreen:
The only bad damaged thing is that bloody flat washer I should not had added. :oops:
