Page 2 of 5
Re: Jagdtiger No.41 in Germany
Posted: Thu Apr 22, 2021 8:55 pm
by Robert Tanzer
Top details.
Your job of making brass tiles is First class.
Robert
Posted: Fri Apr 30, 2021 8:26 pm
by Vince Cutajar
Love the door mechanism. Great modifications and additions.
Posted: Sat May 01, 2021 4:37 pm
by Marco Peter
Oooohhh nice Sascha!
Very cool is this metallic resin?!?
I just bought a Elegoo Mars Pro 2 last week!
Posted: Sat May 01, 2021 4:56 pm
by Marco Peter
I'll PM you! :-)
Posted: Thu May 27, 2021 6:20 pm
by Robert E Morey
Sasha, Nice work on JT! I never knew the AT armor needed to be thicker than it already is. Will you add battle damage to your model like real one?
Posted: Sat May 29, 2021 8:26 am
by Phil Woollard
Nice work Sascha, and your the first to point out the scale thickness issue, when I find a JT I will do the same mod. This is a most impressive model indeed I can't wait to build one.8)
Regards Phil.
Posted: Sat May 29, 2021 9:10 am
by Chang
Regards Phil.
Hi Sacha and Phil,
Glad to read this. Knew the scale thickness issue has been addressed now.
Posted: Sun May 30, 2021 1:54 am
by Jerry Carducci
Sascha Hornbach wrote:
Wed May 26, 2021 5:54 pm
Hello,
few days since last update here, but it was a bigger step to pimp the frontplate. The original thickness is 250mm so there must be 41,66mm. First I cut off the sides and add 8mm Aluminium to the frontplate. The weldingseams at the frontplate are very wide, and I can "hide" the rest of the thickness behind that weldseam. Looks much scaler now I think. I also do some angles on each plate corner, the original plates also had big angles to weld such thick armor together. You can see this angles on the Bovington and Aberdeen Jagdtiger.
best regards
Sascha
This quite interesting Sasha. I've been debating which kit I want to begin after I'm complete with my M3 Lee. I've not yet even opened my
JT kit yet (I dislike opening things up before I need to) so I'm unsure how those plates fasten together. I'm assuming you needed to drill a new hole and thread it since putting the extra thickness would change the relative positions of the two? Or are you saying that you also made the corresponding slots at the front two side plates ('First I cut off the sides') deeper as well?
Posted: Sun Jun 13, 2021 7:16 pm
by Jerry Carducci
Sun Jun 13, 2021 3:03 pm
Hi Jerry,
sorry for that late answer! The positions of the existing holes must not be changed. I drilled 4 new holes in the inside to fasten the plates together. Yes, you also have to cut the 8mm off the Sideplates because of the thicker Armor.
best regards
Sascha
I like it Sascha, seems a very good modification I'll likely do to my JaTi when I get to it...seems relatively simple to do and is as you said very noticeable when viewing the model from the side. If it was only a few mm I'd be inclined to let it 'slide' as we say here but 8mm is quite a bit; again not condemnation of the kit as it's a marvelous thing I'm very happy to have.
Are you going to try to use steel tracks or stay with the issued tracks? I'd like to try steel tracks for such a large machine even though I know the recommendation is against that. Way over here where I am the fewer things that can break the better off I am...
Posted: Sun Jun 13, 2021 10:14 pm
by Gerhard Michel
My 2 King Tigers and the Jagdtiger are all equipped with Olaf's steel track links, without any issues till now. Also the wearout of the drive train is not too big. Only the Panther / Jagdpanther doesn't work with its steel track links, due to the design of the road wheels (shape and rubber).
Posted: Sun Jul 04, 2021 6:34 am
by Chang
Dear Sascha,
Regarding the details of the gun barrel clamp and rack, maybe the wonderful (but sadly unfinished) works of the late Per Sonnervik are helpful:
https://tanks.lindak.se/#collection/ee9 ... b1142f25d2
Lerh Chang
Posted: Thu Jul 15, 2021 5:48 pm
by Robert Tanzer
Sacha I really enjoy to see your work on your Jagdtiger.
Greetings from Sweden
Robert
Posted: Thu Jul 15, 2021 7:04 pm
by Christoffer Ahlfors
Awesome! :D
Did you weld the lower half to the legs or machine it out of one part?
Posted: Mon Jul 19, 2021 7:00 pm
by Chang
Hi Sascha,
This is an awesome mod. Would you mind sharing the length of the gun barrel lock rack, both inner and outer one? Thank you.
Stay safe.
Posted: Thu Jul 22, 2021 3:53 am
by Chang
Thanks Sascha for the detailed line drawing. So far it is more than I could hope.
In the time comes, I will PM you. Thanks again.
Best regards, :D
Lerh Chang
