Steen's StuG 3 build thread
Robert Tanzer
Has liked: 1122 times
Been liked: 990 times
Re: Steen's StuG 3 build thread
Post by Robert Tanzer »
Thank you for sharing images on your build Steen.
We boys like to get a little dirt on our fingers, dont we. :lol:
Have a great build weekend Steen, and stay safe.
Steen Vøler
Has liked: 62 times
Been liked: 500 times
Post by Steen Vøler »
That's right Robert
Today's work is over and the following was made
Priming the steel metal parts for the lower hull build
Installation of the bushes
Assembled the hull floor, the sides and some of the lower front and rear parts
Everything is just loosely assembled and not loctited except the bushes.
cheers
Steen
Roy Beukeveld
Has liked: 171 times
Been liked: 118 times
Post by Roy Beukeveld »
Hi Steen, you've had a productive weekend for sure, it's starting to take shape, nice! :-)
Kind regards,
Roy
Steen Vøler
Has liked: 62 times
This is one unsual Stug 3 :D
does anybody know more about this
cheers
Steen
Has liked: 1490 times
Been liked: 1695 times
It looks like a stripped down Flak 38.
Have you seen the other pictures on Facebook ?
Steen Vøler
Has liked: 62 times
Hi Adrian, saw another one with a close-up of the canon, and you might be right here
Moving slow ahead with the build - I have primed some more steel parts - build will continue in the weekend - have a busy work week so not so much in the hobby room :D
cheers
Steen
florian rudolf
Has liked: 297 times
Been liked: 645 times
Post by florian rudolf »
Looking good.
In the Famo build I've been on from the first. In my StuG build I'll be one of the last... - Loking to have some impressions from you guys :lol:
So let your weekend being in your mans cave :D
Steen Vøler
Has liked: 62 times
weekend is coming in a short time and so the hours to spend in the man cave :D
Have a question about the hull floor just to clarify the construction principals
To the rear there is a large bolt going in from the side plates to the hull floor. There is not a similar fastening type on the front part.
Will it be the torsionbar alone that secures the sides to the hull floor or am I getting this wrong.
cheers
Steen
yves mouton
Been liked: 741 times
Post by yves mouton »
Hello Steen,
Yes the ends of the torsionbars will fix the hull plates.
I drill and tap on each side 3 extra holes to fix the hull plates so i dont need to fix the torsion bars
in the begin of my build. The torsion bars i will put later in ( other things to do first )
best regards Yves
Steen Vøler
Has liked: 62 times
Thanks Yves
I believe this will be a fine solution to fix the lover hull without the torsion bar installed
cheers
Steen
Steen Vøler
Has liked: 62 times
Sunday afternoon in the workshop working mainly with the suspension stuff and the main sprocket parts
Loctite was the main stuff used here :D
cheers
Steen
Steen Vøler
Has liked: 62 times
not much to post - am busy at work, but managed to place the order for the motionpack :D
cheers
Steen
Robert Tanzer
That's not the worst thing you could do. :D :D :D
I enjoy following your progress with your build.
Steen Vøler
Has liked: 62 times
thanks Robert
Not a lot going on - really busy at work, but managed to install the return rollers and right sprocket case.
When doing a dryfit of the sprocket case, the gear was not able to turn as it should. unscrew the case and noticed that the gear itself had a slight oval surface on the side facing the side plate. Realized this it was a easy fix. Just used my grinder tool and sandpaper to get the gear 100% even on the surface. 5 minutes after the sprocket case was attached to the side again and fully screwed into place. the gear spins like a cat now :D
cheers
Steen
Robert Tanzer
Nice to see the progress.
