DB Late tiger refurbish
- Has liked: 149 times
- Been liked: 660 times
Re: Late tiger refurbish
Well I would have loved to have just bolted my new Fiefel Plate on and moved on to another job, but the problem is the position on the hatch can be improved, so after some cutting soldering, filing and sanding the mod was done.
- Has liked: 1296 times
- Been liked: 1511 times
Nice work.
I would have had a new plate cut
There's quite a bit out of alignment on the very oldest kits
![Laughing :lol:](./images/smilies/icon_lol.gif)
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
Thanks Adrian - 2007 late tiger is a lovely kit, lots of steel parts! nothing major to mod now except for the wheels, will get on with that soon.
A fairly easy job that took longer then expected, one of Steve Winstone upgrade lugs went missing, I searched high and low and when I was ready to throw in the towel I found it outside the garage, I must have searched for an hour or so ...if its it's not looking for a tool you were just using its dropping something on the floor of no return.... must lead to another dimension.
Hi,
More work done to the exhaust guards. What size nuts are being used to hold these on? Kit M3 look too small.
Hi,
Fitted Steve Winstone's excellent late tiger mudguards along with Jack and starter plate.
- Been liked: 1614 times
- Chang
- Has liked: 15415 times
- Been liked: 403 times
Hi David,
Like your jobs of adding aerial storage tube, and re-location of the Fiefel air intake cover plate.
The axis of the 2007 Tiger 1 Driven Gear CE0302, is solid without threaded central hole (as shown on your Tiger 1).
Will you replace it with a threaded one , or use it without any modification?
Lerh Chang
Lerh Chang
Thanks for the comments.
Chang,
I don't see a benefit to doing this as my sprocket cap is a nice tight fit.
Chang,
- Chang
Thanks David for the answer. I just want to learn from you, if it is worthy to modify or replaced.David Brady wrote: ↑Mon Aug 29, 2022 9:34 pmThanks for the comments.
Chang,
Cheers.
A little more done, Steve Winstone C and U shackle with brackets along with castle nuts on tow hitch and cone bolt on starter cover.
- Been liked: 153 times
Where did you get the numbers you applied on the castings?
Great works!
Bruno
Great works!
Bruno
Hi Bruno
Bought off Ebay
Slaters 1105 5mm High Letters and Numerals (White) on exhaust and sprockets I also use
Slaters 1103 White 3mm High Letters & Numerals
Bought off Ebay
Hi,
Fitted one of the front hatches today. These are a combination of working steel mechanism fitted by Steve Winstone, Mark Lawson brass hinges and Armorpax hatch.
DB
DB
