Jadgtiger in the US
Don Gray
Has liked: 15 times
Been liked: 70 times
Re: Jadgtiger in the US
Post by Don Gray »
Heiko Sattler wrote:
Sat Oct 03, 2020 7:39 am
a nice start I'm looking forward to further developments
Thank you sir! Trying to keep to an update schedule...
Current status:
Have assembled the lower hull but wanted to install the panniers and upper hull sides to be able to do the welds underneath. Can't do that without attaching the mantle and the rear compartment bulkhead... So ALMOST ready to do welds underneath, paint the hull in dunkelgelb and doing first pass airbrush detail on the lower hull and road wheels. Oh waiting on fancy bump stops from John @ ECA as well. But should be here this coming week.
Here is a picture I snapped today: Image
Also, have the rear deck rough assembled, added the lifting pipe on the engine cover fashioned from 11/32" brass rod, added extra grab handle above the rear doors ala the Kubinka JT (which I am mostly basing my build off of), starting design of the rear deck MG42 mount for my DiD MG42, made a 3D drawing for the protrusion that's present on the upper left above the rear doors on the Kubinka JT for dad to whittle out on his milling machine, and the circular lug above the overhead grab handle above the rear doors (fashioning out of brass pipe and body filler).
Here's a photo showing the details: Image
Ordered a bunch of dress up parts to create casting numbers, add tie downs, dress up exhaust armors, ordered a jack and some other pieces I can't remember.
Peter Quambusch
Been liked: 1045 times
Post by Peter Quambusch »
Hi Don. JT looks good!! Glad you got your option kits. Will pick up mine end of the month at AT...
RC shouldn´t be a big problem. Keep the JT "jacked up" and play with the varios settings / programmings, till you´re happy!
It might take a little (as it did for me), but you´ll get there!
And keep postings pics!!
Peter
Don Gray
Has liked: 15 times
Post by Don Gray »
More progress today!
I've been "ready to flip this over" for a week and since the fancy bump stops from East Coast Armory came in thats actually just about true.
Finally...
Need to get the last 2 bump stops installed and THEN I will be ready to flip it. These look fantastic but do require some modification of the hull to mount them in the scale locations using the scale holes.
Finished up some stuff on the rear fighting compartment bulkhead. Still have to mount the "protrusion" over the left hinge and door. And the MG mount point above the top grab bar.
Chang
Has liked: 16559 times
Been liked: 487 times
Post by Chang »
Nice on the building and modifications, Don. It will be a good JT model for sure.
Just my 2 cent: I notice the 3rd grab handle added on top of the rear hatches. For me it is a bit higher, compared with the one in the real JT photo. It will cause an in-convenience if you wish to add "the circular lug" above later on.
With regards,
Lerh Chang
Don Gray
Has liked: 15 times
Post by Don Gray »
Chang wrote:
Tue Oct 06, 2020 10:26 am
Chang,
Thank you. You may be correct. Was trying to eyebal it from photos. If it's a issue I'll have to move it. Find out soon enough the circular feature is next.
Has liked: 161 times
Been liked: 830 times
The hull is looking great Don, nice job on the welds! The grey primer really brings out the details.
Don Gray
Has liked: 15 times
Post by Don Gray »
<David Attenborough>
"Here we see the poor turtle... unable to right itself and destined to starve"
</David Attenborough>
Christoffer Ahlfors
Has liked: 746 times
Been liked: 359 times
Post by Christoffer Ahlfors »
Ah, reinforced floor at the front! Nice! :D
Don Gray
Has liked: 15 times
Post by Don Gray »
A whole pack of milliput later... under hull welds.
Can anyone validate the layout of what the engine access hatches were? I found this for the King Tiger should be very close.
Thanks in advance!
Charles A Stewart
Has liked: 510 times
Been liked: 928 times
Post by Charles A Stewart »
Have you tried Panzer Basics, http://www.panzerbasics.com/panzer/02_a ... er_B_2.htm
Cheers Charles
Richard Goodwin
Has liked: 294 times
Been liked: 291 times
Post by Richard Goodwin »
Impressive stuff Don......I'd better order a crate of that beer :twisted: :D
Don Gray
Has liked: 15 times
Post by Don Gray »
Charles A Stewart wrote:
Fri Oct 09, 2020 4:41 pm
Cheers Charles
Charles!
THANK YOU! I did see these a while back and I knew Per had some drawings but had forgotten where I saw them. Very helpful sir!
Don Gray
Has liked: 15 times
Post by Don Gray »
Rough layout...
Don Gray
Has liked: 15 times
Post by Don Gray »
A little texture... Apparently I'm pretty good at painting crappy
Don Gray
Has liked: 15 times
Post by Don Gray »
Got the basecoat on everything lower hull wise. Tried my hand at some airbrush highlights. This was not my first attempt... :wink: But MAYBE starting to get the hang of it. Barely.
