Lucky to get an Sdkfz-222 - Looking for Advice
Has liked: 1363 times
Been liked: 1556 times
Re: Lucky to get an Sdkfz-222 - Looking for Advice
Leonard, did you get this 222 working ?
Leonard Rose
Post by Leonard Rose »
HI Adrian
I have not been able to track down why the motors will not operate and do not know of anyone that is local that I can ask to go through the electronics and wiring. With that said, I would like to know if there is an option to purchase replacement electronic components for a '222, such as the following parts:
Power supply module
Speed control module
Auxiliary function module
sound module
Plug and Play Wiring pack
Thank you for your assistance
Leonard
You would need to speak to Armortek to find out if they could make up a custom motion pack for the 222 using the current range of modules.
Leonard Rose
Hi Adrian
I thought you were also affiliated with Armortek. Just sent off an inquiry to them for replacement electronics and will advise you of the outcome.
johnny johnson
Been liked: 35 times
Post by johnny johnson »
Got it running? if you dont use the stock Armortek electronic you should look at the Syren 25A 24volt controller, I have used x2 of these in different models and I have a friend that also uses them, to me they are simple to use and in the US only cost about 75 bucks plus another 25 for a BEC unit.
