2019 No. 02
Brian Ostlind
Has liked: 975 times
Been liked: 2068 times
Re: Brian Ostlind’s new thread
Post by Brian Ostlind »
Chang
Has liked: 16568 times
Been liked: 487 times
Post by Chang »
Brian Ostlind wrote:
Mon Jul 27, 2020 5:11 am
Hi Brian,
Is that a large Lazy Susan slip ring there? It's great if yes.
Can you tell me the diameter of it. Thanks.
Lerh Chang
Brian Ostlind
No progress on KT this week. Air strikes have halted the build.
Brian Ostlind
Doing some test paint mules.
Brian Ostlind
This doesn’t look like a bad starting point.
livecode json
Brian Ostlind
Hmm modulation.
Brian Ostlind
Re: Brian’s King Tiger
I got some motion and sound packs unboxed and started organizing parts and laying out the build. Also honed in on a final camo pattern.
Scott Boyd
Has liked: 45 times
Been liked: 23 times
Post by Scott Boyd »
Wow, in the 4th picture, look how bent the side panel is! Mine was like that to:-(
Tom Wittstock
Been liked: 18 times
Post by Tom Wittstock »
Hello Brian, I see in the back ground some electronics.. What I'm looking for when you're ready of course is pictures of your bench test. It is hard to follow the electronics once inside the tank if you know what I mean so if you could take some pictures of your bench test on a bench instead of inside your tank would be great. No hurry..........Thanks form Tom
PS. I have the motion pack and plan on ordering the other remains packs later on.....
Brian Ostlind
Tom Wittstock wrote:
Sun Dec 20, 2020 4:55 pm
I am happy to give it a go but if you haven’t looked at the motion pack manual yet you might want to read that because it has both layouts exactly as you described pictured in it.
Hope that helps.
Brian
Has liked: 1485 times
Been liked: 1695 times
Did you get a free spider or is he from the inspection team at your Tank Workshop ?
Brian Ostlind
Adrian Harris wrote:
Mon Dec 21, 2020 12:52 am
Just one of my roommates
Brian Ostlind
Phil Young
Has liked: 40 times
Been liked: 59 times
Post by Phil Young »
And so it begins! Don’t forget to bend the ends of the locking tabs up slightly before fitting Brian!
Phil.
Chang
Post by Chang »
Phil Young wrote:
Thu Dec 31, 2020 10:33 am
... Don’t forget to bend the ends of the locking tabs up slightly before fitting Brian!
Phil.
A small flush side cutter pliers will do the job—— even after fitting—— easily. :D
