Sdkfz 7 Build
- Has liked: 149 times
- Been liked: 660 times
Re: Sdkfz 7 Build
Hi,
A little more progress, I've been putting off trying this for a while as it's a little tricky. Now for some meditation before I attempt the other side
- Has liked: 2227 times
- Been liked: 7003 times
Re: Sdkfz 7 Build
That's about as tricky as it gets David, nice detail. ![Cool 8)](./images/smilies/icon_cool.gif)
Re: Sdkfz 7 Build
Your not wrong Phil...anyway time to fit Steve Winstone front tow hitch with starter pins, made from steel it's a great addition to my halftrack. Many thanks Steve, I know you had fun making it.
- Been liked: 1614 times
- Has liked: 97 times
- Been liked: 446 times
Re: Sdkfz 7 Build
Very interesting bolt pattern... what's the engineering idea behind this? The asymmetric pattern has obvious applications in something like a gear train or a wheel/dolly that has to have a very specific balance. But wondering why the Germans would have used such an odd pattern for what is, in essence, a dolly wheel?David Brady wrote: ↑Tue Sep 17, 2019 8:27 pmWheel bolt configuration changed to resemble the real vehicle
Beautiful workmanship on the whole build! And definitely interested in the engineering behind this.
RPR
Re: Sdkfz 7 Build
Thanks for the comments. The hub was flat on one side ...maybe clearance/balancing issue.
Re: Sdkfz 7 Build
Had around 5 hours to play on my sdkfz7 today so I decided to tackle the front and rear ribs on the bonnet but as usual I misjudged the task, after about three attempts I managed to get one of the ribs sodered. I used 1/16 half round beading. The problem is its got a mind of it's own when you heat it up!
- Fabian Bekkers
- Has liked: 190 times
- Been liked: 105 times
Re: Sdkfz 7 Build
Very Nice David beautiful details I start on mine when I have finished the kingtiger.David Brady wrote: ↑Sat Sep 21, 2019 6:53 pmHad around 5 hours to play on my sdkfz7 today so I decided to tackle the front and rear ribs on the bonnet but as usual I misjudged the task, after about three attempts I managed to get one of the ribs sodered. I used 1/16 half round beading. The problem is its got a mind of it's own when you heat it up!
My sdkfz7 was partly built so it would be quite a challenge
Huzaren van Boreel![🫡](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1fae1.svg)
Re: Sdkfz 7 Build
Hi,
Opened up the slots around the sprockets, this was a case of pushing through a small amount of metal to finish.
Re: Sdkfz 7 Build
Hi,
Not to much to report on the sdkfz 7 front except some nice quality upgrade parts supplied by Michal Matata
Re: Sdkfz 7 Build
They are a work of art Dave, lucky to have these craftsmen around, imagine making them, very difficult and time consuming, worth every penny if you enjoy your vehicles, regards simon, p.s. lets see some more building, i am into these 7s at the moment.
Re: Sdkfz 7 Build
Your not wrong...I'm trying to resist ordering Michal's front rim and tyre upgrades ...... don't know how much longer I can hold off!
I've got stuck opening up the holes in the wheels but will get back on it soon.
Re: Sdkfz 7 Build
Hi,
Three wheels and tyres ordered ....something to look forward to!
