Florians FAMO build
michael haerle
Been liked: 6 times
Re: Florians FAMO build
Post by michael haerle »
Hello Florian,
I am present with the screws. Take these for 2 Famo Kit. If you have any other optimization projects in this regard, please let me know, I am also part of 2 Famo models.
Let me know how it goes ...
many Greetings
Michael
Hallo Florian,
ich bin bei den Schrauben dabei. Nehme diese für 2 Famo Modelle. Wenn du noch andere optimierungs- Projekte diesbezüglich hast, lass es mich wissen, bin ich ebenfalls für 2 Famo Modelle dabei.
Lass mich wissen wie es weiter geht...
Viele Grüße
Michael
florian rudolf
Has liked: 292 times
Been liked: 639 times
Post by florian rudolf »
Hallo Miachael,
ich werde einige Schrauben tauschen. Eigentlich alle die man sehen kann. Ich halte dich auf dem laufenden was die Sonderbestellung an geht.
Hello Michael,
I change all screws they you can see at the model. I tlee you if I know how it goes.
Has liked: 762 times
Been liked: 1738 times
Hi Florian
Are these M3X6 screws what you are looking for?
https://www.ts-modelldampfmaschinen.de/ ... 8-569.html
florian rudolf
Hi Vince,
yes thats the right one... Thanks allot for the link.
florian rudolf
Thats the reason why
florian rudolf
Did some work on the body....
That size of hex head looks perfect. I don't know if you noticed but the hex heads in the link I sent you are high heads.
florian rudolf
Yes I've seen that. So I'm waiting till Fa. Knupfer tell me if they can make the smal haeds with 6mm or not.
If not than I'll take yours with the high haed.
Phil Dawe
Has liked: 754 times
Been liked: 276 times
Post by Phil Dawe »
Anyone in UK needing small hex head M3 screws should try:-
www.ekpsupplies.com
The made a batch up for me a couple of years ago. Reasonably priced and quick delivery.
florian rudolf
The last fiew days I did some woek cross the building instruction.
The front axel will be install easy, but the body is a bit tricky. So it needs some complains with flex ;)
I put the frame with the rivet, before install the side body parts. I did'nt need loctite.
florian rudolf
...Evening atmosphere....
Has liked: 2259 times
Been liked: 7147 times
Are you going to round off the front axle pivot frame? I have thought about it. Regards Phil.
florian rudolf
Hi Phil,
I also thought about it. I will leave it like this.
1. You hardly see it
2. It's alu and if it gets less stuff, it could break under the strain.
Florian
florian rudolf
I did some more body work jeseterday, an paint the alu ground to finish the frame. Picthures come later.
Bevor I build the load area from the FAMO. The side wals I fixed also with the rivet. It ab litle tricky because the loading floor. On front of the side wals aro no more rivet in spce the side flap. In this space I braze it, so its a good connection to the floor I think.
Its an important tool for body shop
florian rudolf
This weekend I saved the metal against rust. With paint it looks even better...
Did some more body work
