The V2 project
Has liked: 2263 times
Been liked: 7149 times
Re: The V2 project
A bit more progress, the fuel tank has now been constructed and attached, the next job is to build the guidance section which is located above the alcohol/water tank, (the red bit, the rockets fuel tank) and just below the war head, everything slides into the rocket body nicely, as you can see I have had to create bulkheads to centre the internal structures , thus keeping everything plumb and supported . Most of the internal detail will never be seen but we all know it's there, Although i will provide tantalising glimpses of the detail through cut away sections of the body ........Phil.
Last edited by Phil Woollard on Sun Sep 09, 2018 8:58 am, edited 3 times in total.
yves mouton
Been liked: 567 times
Re: The V2 project
Post by yves mouton »
Hello Phil,
Awesome job so far.
Best regards Yves
Re: The V2 project
Some more progress on the V2?
The rocket motor outlet cone is very clean in its fresh coat of grey, I have no idea if each motor was test fired before deployment but I think I will weather the combustion chamber and jet pipe all the same.
A good reference photo of the jet vanes
Internals all fitted
Very snug fit in there
Ive used an aluminium paint which looks a bit stark right now but it will be weathered .
You can just make out the burner heads of which there are many up in the combustion chamber
The jet vanes made and  fitted, the kit doesn't come with any detail what so ever.
fully adjustable jet vanes, the matt black finish lightly burnished gives the illusion of the graphite used on the real thing
Christian Steinhauer
Been liked: 19 times
Re: The V2 project
Hy Phil,
nice how it comes together, I like the technical details of the V2.
Only a suggestion for the trailer question, another option only for transport is the Vidalwagen.
Christian
Re: The V2 project
Thanks Christian, I have just ordered the 1/35 kit to use as a template/reference kit. The Vidalwagen looks fairly straight forward to build if a little light weight, I just need to source some more suitable wheels as I really need to construct the light panzer recovery trailer from those 88mm bogies that i have.
I wonder if Armortek will produce the recovery trailer some time soon, i think it sure would sell well with all those half tracks inc the Famo out there.
I must post a want for maybe 6 wheels and tyres, or contact Monique to see what they might have in stock.......regards Phil.
Who needs a dedicated V2 trailer?
Re: The V2 project
Now working on the telemetry guidance section then on to the warhead. I suppose the internals could be on display along side the rocket body.
The rocket motor is sitting on a tin to raise it up to the correct height in relation to the rocket body.
Re: The V2 project
Wow, it looks very good.
What is the diameter of the tyres from the eight-eight trailer? Do you know these tyres from Schink
https://schink-1-8.de/epages/b51e55ad-4 ... 96fe7b1127
The Dunlop has 150mm outer diameter the Continental 135mm.
Christian
Re: The V2 project
Interesting web site Christian, the Armortek tyres fitted to the 88mm bogies are ; 160 OD, 95 ID and 35mm wide. I would rather have Armortek wheels and tyres and hubs but its down to whats available regards Phil.
Until the kit arrives I cant check of the trailer wheel size but I bet there not far off, I would also need the hubs to suit.
Re: The V2 project
I can't find the real tyre sizes from the trailers, but the Dunlop should fit the Maillerwagen and the Continental the Vidalwagen.
Schink and Pistor ( https://www.pistor-modellbau.de/shop/reifen/1-6/ ) also have nice rims for the trailers, better matching
than the Trilex rims.
Once again "ein Leckerding" what you are building.
Christian
Re: The V2 project
If you have around 40 mins spare this video of "operation backfire" tells all, it covers every aspect of the V2 A4 rocket as the allies evaluate the system.
The spherical jobies are the 2 gyros
All scratch built  from my interesting looking parts bin and plasticard
Its a tricky thing to photograph
Rolf Mönke
Has liked: 50 times
Been liked: 139 times
Re: The V2 project
Post by Rolf Mönke »
Super!!!
Greetings from Hamburg
Rolf
bosswilli-hh@gmx.de
Re: The V2 project
Just got to show you guys this guys work, it's amazing.it only exists as noughts and ones of course! :D
Re: The V2 project
I think I have done enough with the control room quadrant for now, no more detail needed.
Has liked: 126 times
Been liked: 755 times
Re: The V2 project
Wow Phil, looking excellent. When is the launch date?
Super job.
Re: The V2 project
Thanks Bob, as I said I will be filming a tethered engine burn but its going to stay firmly on the ground!
I never really intended to go this far with the V2, well not to this level of detail anyway, I do a bit, think that's enough, then take another look at the research and add some more detail.
There are many different types/marks of the vehicle, with as usual a mix of different components gradually being refined down until the systems all work as intended. It's fascinating to say the least, and as I was involved with research here in the UK of a scaled down V1 (back when I was an engineering apprentice) all the more relevant.
Cant wait to hook it all up to the Famo and see if I can make it all look period and convincing on camera!
Im very grateful to Armortek for allowing this off topic thread, and thanks for all the pm's from you guys expressing an interest. Cheers Phil. :D
I have made a start on the &quot;pointy bit&quot; the war head.<br />I have a large piece of iroko which needs turning from 150mm down to a point of 10mm being 320mm in length
I have made a start on the "pointy bit" the war head.
