OK now the fun starts !
Time to start chopping thing up and moving bits around.
The rear plate requires some work, well to tell the truth quite a bit.
The engine access hatch is undersized and placed to high up the plate.
The armoured exhausts are slightly short and to wide.
The track adjustment covers are to low
The starter crank and coolant heater access covers are the wrong way round.
I am going to make a new engine access hatch 85mm dia and position it 40mm from the bottom of the plate.
The armoured exhaust will be chopped about a fair bit to get the right dimensions.
Track adjustment covers will be repositioned higher up.
Starter crank and coolant heater covers will have to be swapped over.
