TURRET BIN
- Has liked: 4 times
- Been liked: 16 times
NEARLY THERE
Latest pictures of pannier, still needs final rubbing down and priming etc.
The locks and catches work (but not with a key the locks are held closed with a very small compression spring). The top holding brackets have enough clearance for the turret lifting hooks.
Graham
- Been liked: 10 times
- Been liked: 1 time
- Been liked: 177 times
TURRET BIN
I am interested in any photo,s of the Panzer iv so I can gradually develop my model, if you can email them to me, my email address is in the memberlist.
Heres a picture of my tank part assembled ready for the Brixham steam rally
IMG]http://i285.photobucket.com/albums/ll49 ... ONE006.jpg[/IMG]
Graham
- Has liked: 166 times
- Been liked: 849 times
Graham,
Awesome job! Really first rate construction! My hat is off to you for undertaking such an immense project! Its going to be an excellent model. I was amazed by your working jack. I'm am also amazed that you do all of your machining on the lathe - which takes some very creative thinking and setting up.
Keep up the great work.
TRACKS
Hi Allan
They are castings bought from Armortek as I do not have any casting facilities.
Graham
MORE ???S
Hi All
Just in front of the gun mantlet on top of the barrel holding part on the previous sketch,s on this subject posted by Pierluigi is a rectangular part let in with a thin circular part like a pull ring sticking out, what is it?
Graham
THING IN FRONT OF MANTLET
You may be right but it looks a bit flimsy for that and then why fit it to a rectangular plate let into the surface, surely they would weld a hook there similar to the ones on the turret side?
Graham
