Derek's slow build of 004 / 2014 issue
Steve Stuart
Has liked: 258 times
Been liked: 187 times
Re: Derek's slow build of 004 / 2014 issue
Post by Steve Stuart »
Alexandra Palace visited today for the Model Engineering Show. So it was good to see Derek and to see the Chassis in real life. Very impressive to view what has been appearing in the post. Seeing the current project has always been for me a highlight of the show over the last few years!
All the best, Steve
Derek Attree
Has liked: 218 times
Been liked: 183 times
Post by Derek Attree »
Hi Guys
So I have been a bit absent of late this is because I have had a bit of a cancer issue
going on since April last year but I have turned a corner and things are in remission now
but still under 3 monthly review.
I have been quitely doing some detail work on the rear section of the half track riveting
around the doors and the back panel and the side dummy doors.
I am going to work on the long side panels next then start on the seats.
I have also done a bit on the grill and made a replacement radiator cap.
I will post some pictures here in the next day or so.
I am please with the progress this is anouther great subject from Mark.
Been liked: 1643 times
well done derek, good news, i was hopeing all o.k. regards simon
Paul Morris
Been liked: 68 times
Post by Paul Morris »
Hi Derek.
Sorry you have been ill mate but good news for you now ... your a gent keep well and do as the doc says.
See you soon Paul. :wink:
01524 720977
Ian Rodney
Been liked: 53 times
Post by Ian Rodney »
Hi Derek,
Good to see you back on the Forum…sorry to read that you were ill, hope you get back to full recovery.
Looking forward to seeing your half track progressing soon.
All the very best for now
Ian
David Brady
Has liked: 186 times
Been liked: 711 times
Post by David Brady »
Hi Derek
Glad to hear your doing well! That cancer should of known better then to mess with someone that has built four armortek models. looking forward to viewing your new pictures
Kind Regards
Derek Attree
Hi Guys
Thanks for the support.
Photos to follow.
Derek Attree
Hi Guys
This is the rivit detail on the rear end.
I have also made a new lower door.
Derek Attree
Hi Guys
This is the detailed side doors
This is the radiator grill and the new radiator cap.
Derek Attree
Hi Guys
This is the front mud guards with more rivets....
Derek Attree
Hi Guys
Reprofiled the rear quater to blend it all in.
So thats it for now
Derek Attree
So guys I have been doing some more I got some of the original cast engine grills from Gill for
a small sum of money I think they look better.
I have soldered the side panel trim with soft solder and a blow torch
and the added a lot of rivets.
Derek Attree
Hi Guys the rivets on the side plates
I have lightend the seats by hollowing them out and removed the center of the rear
to make the hinge froward section this also removed 1.5 kg of metal.
Derek Attree
Hi Guys
Tim cattons very nice number plates
Ian Rodney
Looking good Derek,
Your Half Track is coming along well, like your cast engine grills, and all the work you've done so far on this kit.
Ian
