Hi Stephen/Chris
Looking forward to see how you approach this issue. I have been working on the gun elevation/depression for a few weeks now but have had a few problems getting the limit switches to work, I think that is now solved I swopped the leads over on the switches as I think I had the switches the wrong way round. (this electronic stuff is doing my head in but I am learning all the time)
Another problem that I am going to start looking at is the way the leadscrew works, the gun barrels movement is not a very smooth operation. The gun barrel moves up and down slightly when you are elevating or depressing the gun barrel on the radio control stick.
Centurion query
- Been liked: 213 times
Re: Cent Radio Control Problem
Hi all
I am having a few problems with my 7C futaba radio control. I done the basic bench tests installed the motors and amplifier and programmed the sound card everything seemed fine, I ran it on tick over for about 1/2 a day to run in the speakers and all seemed ok.
Then I was doing some other work on the tank and went to switch off the power supply module and it would not as the left hand motor went into full reverse the only way to stop it was to disconnect the battery, this has happen twice now.
Today I was connecting all of the other options to check everything was working, the only connection that I did not do was the con rod to the servo for the recoil everything worked fine. Connected the con rod but did not work very well (this needs some work to improve its operation in the sleeve) as I was thinking about what to do about this the left hand motor and sound went into full reverse. I moved the stick control and it went back to tick over. this happen 4 times over a few minutes even though all of the sticks on the transmitter where in neutral.
This very concerning as I dare not take it off the test bed and try out on the ground for fear of the left hand engaging on its own. I have had a look other peoples builds on the forum but found no mention of this type of problem.
Any help and suggestion would be gratefully received.
- Been liked: 15 times
Re: Centurion query
Have you still got the ratchet on the left stick on the transmitter. If you have you will need to buy a centering spring.
Lee
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Re: Centurion query
Hi Lee
Thanks for the reply, yes the left hand stick is still on the ratchet. Do you know where I can purchase a spring from?
- Mick Regan
- Has liked: 34 times
- Been liked: 6 times
Re: Centurion query
Hi Dave
Part number is Y-MA8036. Here's a few stores with stock :
http://www.pegasusmodels.co.uk/prodcat. ... &x=28&y=15
http://www.hobbystores.co.uk/default.as ... d=Y-MA8036
http://www.rcmodelcentre.co.uk/index.ph ... ctId=14006
http://www.sloughrc.com/default.asp?WPG ... d=Y-MA8036
Hope this helps
Mick
Hope this helps
Mick
Re: Centurion query
Hi Mick
Many thanks for the information I will get one ordered today and see if that fixes my problem.
Re: Centurion query
Hello David
You have to take the back off the transmitter to fit. Easy job. Look how the others are fitted before doing it. It will center the stick putting it in neutral.
If you are struggling to get on I might have one in stock.
Lee
Lee
Re: Centurion query
Hi Lee
Thanks for the input I have ordered one this morning (I did not know that you might stock them) I will fit this as soon as it comes hopefully this will solve the problem.
