Hi Simon,
you have built a really nice 222. I like the color.
Bodo
My 222
- Been liked: 25 times
- Been liked: 1767 times
Re: My 222
looks convincing simon, these 222 are a good model, plenty of options, well done, regards simon manning.
Re: My 222
Excellent model Simon !
Could I ask you raised the gun mount to its correct position?
Larry
Larry
Lawrence Godson
- Has liked: 7 times
- Been liked: 46 times
Re: My 222
Hi Larry.
My 222 is not yet finished, but I found if you place the steel strip that the gun cradle is fixed to, and in turn should be fixed to the underside of the turret ring, on the top side of the turret floor, then the guns sit at about the correct height. You'll have to put some kind of spacer on top of the pedestal to fix the raised mechanism and allow for a smooth rotation, but I think it should be quite an easy mod when all is said and done. When I can I'll post a picture that will be better than a description. I'd like to do some more mods to the guns and gun mount, but at the moment I'm snowed under with moving and work. I hope that helps to explain things?
Simon.
Simon.
- Has liked: 161 times
- Been liked: 830 times
