mi first panzer III
Juan Carlos
Re: mi first panzer III
Post by Juan Carlos »
If they are three pieces of 3 mm of PVC, and 6 mm wider than the base.
Frank Breitenbach
Has liked: 54 times
Been liked: 689 times
Post by Frank Breitenbach »
Hallo Juan
What I meen is can you send us an picture from the inside from your hull/top of the floor that we can see the mounting of the swingarms.
Frank
Has liked: 126 times
Been liked: 757 times
Beautiful work Juan. Show us more when you get time!
Juan Carlos
Image Image Image
Juan Carlos
Image Image Image Image Image Image Image
Kent Wiik
Has liked: 6 times
Been liked: 194 times
Post by Kent Wiik »
Hi Juan,
A PzIII is by far to early era for my key interest of WW2 (late 1943-the end) so I have not the knowledge to comment the accuracy of your build but...
I must say your details look stunning!
Me as an accuracy nut head love to see another fellow builder with the same addict as myself that’s why I love to follow your build.
Keep the photos coming!
It´s all in the details!
Juan Carlos
Hi Frank, I will try get more photos, materials used to make the pieces are any material that can serve me because I have metal lathe, use wood, PVC, resin, in Spain there is a mall of bricolage, Leroy Merlin, and with many pieces as the profiles of wood, nuts 1,1.6, 2, 2.5, 3, threaded rebar, etc. Image
Has liked: 1381 times
Been liked: 1578 times
That access hatch looks superb - such a neat way to improve the hinge :D
Juan Carlos
Image Image Image Image Image Image Image Image Image Image Image Image
Juan Carlos
Christian Steinhauer
Been liked: 19 times
Hello Juan,
very nice work. How do you make the bump stopps. I'm still milling mines.
Christian
Been liked: 1635 times
extremely well made so far juan,, another great panzer 111, regards simon manning.
Hi Juan
Simply fantastic!
best regards
Lawrence Godson
Post by Lawrence Godson »
Very very well done! Any chance you might sell the guides some day?
Lawrence Godson
Juan Carlos
Hello everyone, Christian, the bump stops are made with aluminum tube 30x15, cut to required lengths and the rest is made with Evergreen sheet of 2 mm and 3 mm PVC, the same holds for the running board brackets Steve Winstone, I have added a 20x10 tube cut to measure, and on top I added a strip of aluminum with round, I hope you understand everything right, thank you all. Image Image
