Comet 2010-027
- Has liked: 161 times
- Been liked: 830 times
- Been liked: 15 times
- Has liked: 10 times
- Been liked: 224 times
- Been liked: 223 times
Johns Comet
Hi John
You have a great looking Comet and your details.
Did you find that your gun wouldnt close down shut with the barrel in
before you added your fastening detail and does it lock shut now?
Phil,
The travel lock wouldn't bolt down tight because the hexagon shape is smaller than the barrel diameter. From what pictures I've seen that is also true of the real thing and it just clamps on the barrel without coming all the way down.
My modified one now also behaves like that and does now clamp round the barrel.
John
John
Gun Crutch
Thanks John
Thats what was throwing me,because the photo's in the armor photgallery
looked straightish,but there was a long thread on the clamp fastener,and I think the left hand leg of the clamp might have been longer at least as long as the bottom angle bit of the crutch.
Another one for my list,I've just bought a 100 watt bulb for my spare bed
room now the nights are darker quicker and the clocks have gone back,
they have pinched my Tank time.
Mick,
I have been on the bearing cap cover securing set screw case only this morning. I am using 10BA threaded set screws with 11BA heads. The slightly smaller head appears to be a reasonable proportion to the cap and importantly would if scaled up to full size allow a socket spanner to be fitted. I have had to trim down the length and had glued them into the bearing caps after slightly countersinking the hole from the underside.
Check out www.modern-screws.co.uk. I cannot actually find the screws I bought this morning in their website, better to give them a call on 013322 553224. It is a goldmine of fastenings and if they haven’t got something they say that they will have a go at finding it.
Hope this helps.
Paul
Hope this helps.
Paul
