yves tiger 1 update
Tim McCarthy
Been liked: 31 times
Post by Tim McCarthy »
Great work on your tank
I think that engine looks great
I look forward to seeing it painted
Keep the pictures coming.
Timbo
yves mouton
Been liked: 741 times
tiger 1 engine
Post by yves mouton »
Hello Tim
Thanks for the compliment, the engine is not top quality
but it looks good for resin, some little parts dont came out the mold
good ( they restore them by hand ) afterwards i'am satisfied.
regards Yves
yves mouton
tiger 1
Hello everybody,
I got some new pictures
Uploaded with ImageShack.us
now am gonna work on the tiger
regards Yves
chris quick
Post by chris quick »
Hi Yves
Great work on your tiger!
groetjes uit Holland
Tim McCarthy
G’day Yves
How did you mount the front bar that the spare track is hanging on?
Also what did you make it out of or did it come with the kit?
Timbo
yves mouton
track link stowage
Hi Tim,
I used a ALU L shape form from 10mm and 1,5 thick, you cut it to the correct lenght and make a cut on both sides from 10mm and bend it to the front of the tank. If you have bend the flenses you cut the rest of the bar to fit between the tank.Then drill a hole on both sides from 3mm. Then i used a drill from 2,3mm for drilling the side panels of the tank and used a 3 mm tap for the countersink screws. I hope you understand my explanation because my english is not very good. Here are better pictures of the track link bar and some new build pics of the tank
Install of the Armortek engines and turret track links
And smoker from Armortek
regards Yves
Hi Yves
what a great looking Tiger you have! Love that turret assembled and sitting there by itself. looks very cool.
Look forward to your next post.
the Tim in California, not Australia :D
yves mouton
tiger 1
Hello everyone,
This week i made a couple of jerrycan holders that i put together
with copper rivits, and dit some work on the engine compartment
I have also install the rear reflector, the convoy light and the jack
this picture i post later
regards Yves
yves mouton
tiger 1
Hello again,
I'am a few steps further on my tiger,
first i put the idler an wheels and the drive sprockets on
The second step i put on Mike's tool latches and started with the deluxe antenna set.
And cutting my maybach engine in two, because i'am gonna put my batteries flat in the tank, so one battery is under the engine.
Because i'am using the blankfire it is necessary that the batteries
are flat in the tank,so the second battery comes a little part on the turret hole.
There is some work to do on the engine.
regards Yves
yves mouton
tiger 1
Hello,
I have some details on the engine fitted.
The engine is now ready to paint.
regards Yves
John Fitzsimons
Has liked: 6 times
Been liked: 822 times
Post by John Fitzsimons »
Looking great. Looking forward to seeing how engine will fit with batteries mounted. Somthing I would like to do also.
What did you use to fit the tool holders? Did you use rivets? If yes, what size?
Well done.
John
yves mouton
tool latches
Hi John,
The tool latches comes from Mike Stannard and with the latches
are very tiny self tap screws, first i drill a hole 1,5mm and then i glue the tool latch on the tank and secure with the screw the screw have the same bore but you can screw it in the tank,
you have to be careful otherwise you can break the screw
regards Yves
yves mouton
tiger 1
Hi everyone,
I'am a few steps further with the engine compartment.
I made also 2 boxes to put the speakers in, and i made a tray
for the power suply module. I use velcro strips on the modules,
to secure them in the tank. The engine is also secure with velcro.
regards Yves
John Fitzsimons
Has liked: 6 times
Very neat set up. Engine looks great in place.
yves mouton
tiger 1
Hello everyone,
My tiger 1 is almoast ready to run, i have to put some details on the deck, the tools, the antenna(s), the tow cables, the feifel tubes and some other stuf.
I'am now working on the electronics and the blankfire.
Here are some new pictures.
regards Yves
