Page 2 of 6
Posted: Thu Feb 04, 2010 9:15 am
by leesellars
Hello Sarah
It was nice to speek to you at Stoneliegh.
Lee
Posted: Thu Feb 04, 2010 10:45 am
by Dennis Jones
Hey Sarah are you going to Yeovilton on 13th Feb ?
Dennis.
Posted: Sat Feb 06, 2010 2:45 pm
by Sarah Frazer
Dennis Jones wrote:Hey Sarah are you going to Yeovilton on 13th Feb ?
Dennis.
Hi Dennis,
I'm afraid I can't make the model show on the 13th, are many tank people going?
Sarah
Posted: Sun Feb 07, 2010 10:33 am
by Dennis Jones
Hi Sarah,
Yes about 9 or 10 I think. I am taking my Tamyia 1/16th King Tiger RC model with sounds etc, not in the same league at the 1/6th. The PZ111 build is coming on though, trying to source paint at the moment. I nearly wasn't going as it clashes with an Autojumble Classic Car event at Shepton Mallett (another hobby). That's on for 2 days but all the lads from the Kit Car Club are going up on Sat. Your build looking good.
Dennis.
Posted: Thu Feb 18, 2010 9:43 pm
by Sarah Frazer
Hi Guys,
Well the suspension arms are finished for now, I'm very glad there is only 12 of them!
Milliput was applied to from the 4mm disc to the 16mm base to make the cone section. This was quite easy to form as you can just sand between the disc and base, Milliput was also applied to the soldered joint at the rear of the brass tube.
Disc were also turned and these have been fixed to the suspension arm bases as well. Epoxy was put into the void between the brass tube and the suspension arms to stop the ingress of any water.
Photo below of the suspension arms.
Next jobs are chamfering the escape hatches and reprofiling the front and rear bump stops.
Regards,
Sarah
Posted: Fri Feb 19, 2010 5:12 am
by Stephen White
Sarah
They look superb. You've done a great job. The suspension mods seem to go on forever, a real Forth Bridge job, never quite get to the end. Well worth all the effort though.
The legs were cast and there is a quite prominent casting seam on the outside surface, whichcatches the light and doesn't take a lot to do with some Plastruct rod:
Hope you don't mind the suggestion - the last thing you need is someone making work for you,
All the best - thanks for posting and look forward to seeing the rest of your build.
Posted: Fri Feb 19, 2010 8:05 am
by Sarah Frazer
Hi Stephen,
Thanks for the suggestion and the photograph. I'll pop out to the model shop today and get some plastic rod. Please keep the suggestions coming, I'm grateful for any help.
The suspension arms have gone on a bit, but now they are virtually finished I should make reasonable progress.
Thanks again,
Sarah
Posted: Sun Feb 21, 2010 8:14 pm
by Sarah Frazer
Hi Guys,
Over the last couple of days I've manged to bevel the Escape hatch door. I was going to bevel the fixed bit of the hatch, but there's not enough material there to bevel. I might add some filler to the sides and bevel that at a later date.
I've also roughly machined the front/rear bump stops to a better profile, they still need hand filing to finish off.
It's nice to progress with something a bit quicker, the suspension arms have taken quite some time
Sarah
Posted: Mon Mar 29, 2010 2:19 pm
by Sarah Frazer
Hi Guys,
Well after being away from home, short stay in Hospital and recuperating, a month has gone by with no work on the Panzer
Anyway back to the build at last!
I've finished off filing the Bump Stops and I've also tried Stephen's technique on the surface, with a Dremel and a Wire Brush. The finish does look good, being more cast than machined, photo below:
I've also done more work on the Escape Hatches, the sides have been bevelled, an interior section machined, a catch made and Cone Nuts fitted. Quite pleased with the result as I'm quite new to Milling.
Next are the Suspension Units, a new Front Lower Deck and Transmission Hatches, then I'll start assembling the chassis. It will be great to see it coming together.
Posted: Mon Mar 29, 2010 4:26 pm
by Tim Bowman
Great looking parts Sarah. Looking forward to your hull assembly and future work on your PIII.
Posted: Mon Mar 29, 2010 4:36 pm
I like the look of these modified hatches
How did you mill the curved corners, or did you do them by hand
Posted: Mon Mar 29, 2010 10:09 pm
by Sarah Frazer
Adrian Harris wrote:I like the look of these modified hatches
Hi Adrian,
I milled a chamfer, to a marked radius, then finished by hand.
Regards,
Sarah
Posted: Tue Mar 30, 2010 10:05 pm
Thanks Sarah.
Those hatches certainly look the part - I like your latches for keeping them closed.
Posted: Tue May 25, 2010 8:37 pm
by Sarah Frazer
Hi Guys,
It's been a bit slow with the Front Lower Deck, but I've been getting used to Milling bits and pieces. A couple of 'Practice' bits later
and I've finished the deck and the Transmission hatches as well. It's been quite a learning curve milling the deck and hatches, but hopefully a bit easier in the future.
Apart from making the resized Transmission Hatches I've also moved the hatch apertures lower down so that the bottom of the Hatch Hinges will rest on the weld line across the deck. I do need to make a little recess on the lower part of the deck for the weld line that runs across.
Just to make Dale happy I've made them from Aluminium as well
Just for a comparison the original deck and my new one.
Regards,
Sarah
Posted: Tue May 25, 2010 9:32 pm
by Dale jordan
Very Nice Sarah . It's much better out of alloy is it !!! No more rusty steel .. HAAAA .... Dale
