Page 2 of 3
Build Log
Posted: Mon May 31, 2010 7:19 am
by David Tannen
Sarah I might use these colours.
Build Log
Posted: Wed Jun 02, 2010 4:27 pm
by David Tannen
06/02/10
Posted: Thu Jun 03, 2010 1:55 am
by David Makaras
Hi David. Nice work.
I've noticed your turret fits together better than mine. Did you alter it in some way?
Posted: Thu Jun 03, 2010 2:40 am
by David Tannen
Hi David
The only changes I made was notching the top braces so the side door hinges would fit.
I still have a gap on the back side about 6mm.
Posted: Thu Jun 03, 2010 5:57 am
by David Makaras
Hi David,
Mine also has quite a bit to fill on the side/back turret armour. It wasn't obvious to me in your pictures.
Thanks...
Posted: Thu Jun 03, 2010 3:54 pm
by Tim Bowman
Hi David
Your Panzer III looks great!
Build Log
Posted: Mon Jun 07, 2010 1:03 am
by David Tannen
06/06/10
I did some milling on the Idler caps also drilling and tapping 2 of the bolts to hold the caps on.
Posted: Mon Jun 07, 2010 5:07 am
by Brian Leach
David,
Nice job on the cap!
I haven't posted here before, but given that you did such a nice job on the idler I was wondering if you had seen Jeff's fine work?
http://www.armortek.co.uk/forum/viewtop ... c&start=15
Nice job!!!
Brian
Posted: Sun Aug 01, 2010 2:52 am
by David Tannen
I found some time:
I would like do have the time to do some better details.
I still need to make the starter handle cover, tow hook cover and the two covers under the tow hook cover.
Till next time.
pz111
Posted: Sun Aug 01, 2010 9:45 pm
by Nick Farrugia
Hello
david your pz111 is coming along ,it is good to see it ,and i like your final colour scheam you intend to do .
allthe best
nick
Build log
Posted: Sun Aug 22, 2010 11:21 pm
by David Tannen
Spent some more time working.
Never enough time to accomplish what you want.
http://i857.photobucket.com/albums/ab13 ... 210027.jpg
Thanks for looking till next time.
Build Log
Posted: Sat Sep 04, 2010 8:39 pm
by David Tannen
Added some more details.
Till next time
Build Log
Posted: Sun Sep 05, 2010 8:07 pm
by David Tannen
This is my electrical lay out. Used standoffs on modules, rerouted speaker wires out the sides, made metal brackets for speakers. On test run everything worked fine. Only problem is the machine gun sound. There is
none. The smoke worked fine on the first run, now it just trickles out the sides the fan is working and the block is hot and it has oil. Any help would be welcome.
Posted: Mon Sep 06, 2010 8:06 am
by Armortek
Hi David
The machine gun sound, and all the other sounds are accessed from the Benedini card. Getting these is described in the full Benedini manual on
www.benedini.de.
Your smoker sounds like it has too much oil in it. They best with absolute minimum amount.
Posted: Mon Sep 06, 2010 11:32 am
by Dennis Jones
Hi David,
Will your gun elevation motor clear the speakers and speed controller ?
Dennis.
