Build Log
David Tannen
Been liked: 1 time
Build Log
Post by David Tannen »
Sarah I might use these colours.
David Tannen
Been liked: 1 time
Build Log
06/02/10
David Makaras
Post by David Makaras »
Hi David. Nice work.
I've noticed your turret fits together better than mine. Did you alter it in some way?
David Tannen
Been liked: 1 time
Hi David
The only changes I made was notching the top braces so the side door hinges would fit.
I still have a gap on the back side about 6mm.
David Makaras
Hi David,
Mine also has quite a bit to fill on the side/back turret armour. It wasn't obvious to me in your pictures.
Thanks...
Last edited by David Makaras on Tue Jun 08, 2010 12:52 am, edited 1 time in total.
Hi David
Your Panzer III looks great!
David Tannen
Been liked: 1 time
Build Log
06/06/10
I did some milling on the Idler caps also drilling and tapping 2 of the bolts to hold the caps on.
Brian Leach
Been liked: 3 times
Post by Brian Leach »
David,
Nice job on the cap!
I haven't posted here before, but given that you did such a nice job on the idler I was wondering if you had seen Jeff's fine work?
http://www.armortek.co.uk/forum/viewtop ... c&start=15
Nice job!!!
Brian
Brian
David Tannen
Been liked: 1 time
I found some time:
I would like do have the time to do some better details.
I still need to make the starter handle cover, tow hook cover and the two covers under the tow hook cover.
Till next time.
Nick Farrugia
pz111
Post by Nick Farrugia »
Hello
david your pz111 is coming along ,it is good to see it ,and i like your final colour scheam you intend to do .
allthe best
nick
David Tannen
Been liked: 1 time
Build log
Spent some more time working.
Never enough time to accomplish what you want.
Imagehttp://i857.photobucket.com/albums/ab13 ... 210027.jpg
Thanks for looking till next time.
David Tannen
Been liked: 1 time
Build Log
Added some more details.
Till next time
David Tannen
Been liked: 1 time
Build Log
This is my electrical lay out. Used standoffs on modules, rerouted speaker wires out the sides, made metal brackets for speakers. On test run everything worked fine. Only problem is the machine gun sound. There is none. The smoke worked fine on the first run, now it just trickles out the sides the fan is working and the block is hot and it has oil. Any help would be welcome.
Been liked: 3709 times
Hi David
The machine gun sound, and all the other sounds are accessed from the Benedini card. Getting these is described in the full Benedini manual on www.benedini.de.
Your smoker sounds like it has too much oil in it. They best with absolute minimum amount.
Dennis Jones
Has liked: 10 times
Been liked: 225 times
Post by Dennis Jones »
Hi David,
Will your gun elevation motor clear the speakers and speed controller ?
