Martin's Sturmtiger
Chris.Marshall
Been liked: 36 times
Re: Martin's Sturmtiger
Post by Chris.Marshall »
Martin !
Nice work and thanks for sharing :D
A quick question. What as the size and diameter of the roll pins you used for the swing arms. My T1 is boxed still but I want to have the roll pins ready.
Chris.
Martin Hofmann
Has liked: 151 times
Been liked: 1997 times
Post by Martin Hofmann »
Hi Chris,
thank you for your nice words.
The diameter of the pins is 2,5mm and the lenght is 18mm.
Regards Martin
Chris.Marshall
THAKNS Martin ! :D
Martin Hofmann
Here comes some small update. I made some parts of the back side of the Sturmtiger.
The starter plate with the starter, the armoured covers of the exhausts and all their casting numbers and the casting surfaces are done.
Regards Martin
Martin Hofmann
Here are some more photos from the last built from the motor plate and all the gratings above.
Regards Martin
Martin Hofmann
Here are the next photos of the self made simulated L-angle at the under side of the hull, riveted to the plate above.
The next photos are showing the progress of the hull. Slowly it looks like a tank :D :D
Regards Martin
Chris.Marshall
Nice 'L' plate, definitely doing that on My T1.....
I'm currently roughing out drive sprockets in steel to match my 'Mahoney' tracks.....
C.
